why! N650DU The Keyboard
  1. why! N650DU The Keyboard, The Batteries: step 1, image 1 of 3 why! N650DU The Keyboard, The Batteries: step 1, image 2 of 3 why! N650DU The Keyboard, The Batteries: step 1, image 3 of 3
    • Unlock the button without spring
    • Slide the battery up while unlocking the button with spring
  2. why! N650DU The Keyboard, Access to major components: step 2, image 1 of 3 why! N650DU The Keyboard, Access to major components: step 2, image 2 of 3 why! N650DU The Keyboard, Access to major components: step 2, image 3 of 3
    • Unscrew the two large screws circled in red
    • Unscrew the two small screws circled in green
    • Slide the plate down and lift the
  3. why! N650DU The Keyboard, The keyboard: step 3, image 1 of 3 why! N650DU The Keyboard, The keyboard: step 3, image 2 of 3 why! N650DU The Keyboard, The keyboard: step 3, image 3 of 3
    • Unscrew the circled screws in red and green
    • Put the computer in the position of the second image while pushing a paper clip into the hole of the screw circled in green until you hear a click
    • Lift the keyboard
  4. why! N650DU The Keyboard: step 4, image 1 of 3 why! N650DU The Keyboard: step 4, image 2 of 3 why! N650DU The Keyboard: step 4, image 3 of 3
    • Remove the red circled connector
    • Pull the white drawer that holds the connector circled in blue in the direction of the green arrow
    • Remove the connector surrounded in blue
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 3
All Time: 265
