why! W650SZ CPU Replacement
  1. why! W650SZ CPU Replacement, Battery: step 1, image 1 of 3 why! W650SZ CPU Replacement, Battery: step 1, image 2 of 3 why! W650SZ CPU Replacement, Battery: step 1, image 3 of 3
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ CPU Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 1 of 3 why! W650SZ CPU Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 2 of 3 why! W650SZ CPU Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 3 of 3
    • With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
    • Now you can remove the bottom cover.
  3. why! W650SZ CPU Replacement, CPU: step 3, image 1 of 3 why! W650SZ CPU Replacement, CPU: step 3, image 2 of 3 why! W650SZ CPU Replacement, CPU: step 3, image 3 of 3
    • Using a Phillips screwdriver, unscrew the four captive screws securing the heatsink to the motherboard.
    • Remove the heatsink.
    • The processor and its retention mechanism is now visible.
  4. why! W650SZ CPU Replacement: step 4, image 1 of 3 why! W650SZ CPU Replacement: step 4, image 2 of 3 why! W650SZ CPU Replacement: step 4, image 3 of 3
    • Unlock the processor using a small Torx screwdriver by turning the lock 180 degrees counterclockwise
    • Make sure the locking latch is pointing in the opposite direction.
    • You can now carefully remove the processor from its socket.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 246
