why! W650SZ Hard Drive Replacement
  1. why! W650SZ Hard Drive Replacement, Battery: step 1, image 1 of 3 why! W650SZ Hard Drive Replacement, Battery: step 1, image 2 of 3 why! W650SZ Hard Drive Replacement, Battery: step 1, image 3 of 3
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ Hard Drive Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 1 of 3 why! W650SZ Hard Drive Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 2 of 3 why! W650SZ Hard Drive Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 3 of 3
    • With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
    • Now you can remove the bottom cover.
  3. why! W650SZ Hard Drive Replacement, Hard Drive: step 3, image 1 of 2 why! W650SZ Hard Drive Replacement, Hard Drive: step 3, image 2 of 2
    • Lift out the plastic tab (including the rubber part that holds the HDD in its slot).
    • Slide the drive to the left to disengage the connector then lift to remove the HDD from its SATA3 port.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 6
All Time: 133
