why! W650SZ Keyboard Replacement
  1. why! W650SZ Keyboard Replacement, Battery: step 1, image 1 of 3 why! W650SZ Keyboard Replacement, Battery: step 1, image 2 of 3 why! W650SZ Keyboard Replacement, Battery: step 1, image 3 of 3
    • Slide the latch on the right to the unlocked position.
    • Slide the latch on the left to the unlocked position.
    • Remove the battery pack from the slot.
  2. why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 1 of 3 why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 2 of 3 why! W650SZ Keyboard Replacement, why! W650SZ Bottom Cover Replacement: step 2, image 3 of 3
    • With your #0 Philips screwdriver remove the 2 screws from the bottom panel.
    • Now you can remove the bottom cover.
  3. why! W650SZ Keyboard Replacement, Keyboard: step 3, image 1 of 3 why! W650SZ Keyboard Replacement, Keyboard: step 3, image 2 of 3 why! W650SZ Keyboard Replacement, Keyboard: step 3, image 3 of 3
    • Press gently at the points indicated to release the LED cover strip.
    • Turn the laptop over, then lift the LED cover.
    • Remove the LED cover.
  4. why! W650SZ Keyboard Replacement: step 4, image 1 of 3 why! W650SZ Keyboard Replacement: step 4, image 2 of 3 why! W650SZ Keyboard Replacement: step 4, image 3 of 3
    • The five screws that anchor the keyboard are now visible.
    • Start by removing the first screw.
    • Remove the remaining screws (2-5).
  5. why! W650SZ Keyboard Replacement: step 5, image 1 of 3 why! W650SZ Keyboard Replacement: step 5, image 2 of 3 why! W650SZ Keyboard Replacement: step 5, image 3 of 3
    • Dismount the keyboard from the chassis.
    • Flip the keyboard forward, taking care as it is still connected by a cable to the motherboard.
    • Release the cable latch on the right side of the motherboard connector with a small flat blade screwdriver.
  6. why! W650SZ Keyboard Replacement: step 6, image 1 of 3 why! W650SZ Keyboard Replacement: step 6, image 2 of 3 why! W650SZ Keyboard Replacement: step 6, image 3 of 3
    • Release the cable latch on the left side of the motherboard connector.
    • Slide the cable straight out from its connector.
    • Remove the keyboard.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
33,538 Reputation
283 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 21
All Time: 294
