why! W670SZQ1 Keyboard Replacement
  1. why! W670SZQ1 Keyboard Replacement, The Batteries: step 1, image 1 of 3 why! W670SZQ1 Keyboard Replacement, The Batteries: step 1, image 2 of 3 why! W670SZQ1 Keyboard Replacement, The Batteries: step 1, image 3 of 3
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 Keyboard Replacement, Access to Major Components: step 2, image 1 of 3 why! W670SZQ1 Keyboard Replacement, Access to Major Components: step 2, image 2 of 3 why! W670SZQ1 Keyboard Replacement, Access to Major Components: step 2, image 3 of 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Lift the bottom right cover with the iFixit Opening Tool.
    • Lift the lower left cover with the iFixit Opening Tool.
    • Finally clear the bottom cover completely to access the main components.
  3. why! W670SZQ1 Keyboard Replacement, The keyboard: step 3, image 1 of 3 why! W670SZQ1 Keyboard Replacement, The keyboard: step 3, image 2 of 3 why! W670SZQ1 Keyboard Replacement, The keyboard: step 3, image 3 of 3
    • Once the bottom cover is removed you can start disassembling the keyboard.
    • Start by turning the computer over and then unscrew the screw shown in image 2 of this step.
    • Then using the screwdriver unscrew the bar that hides the screws fixing the keyboard.
  4. why! W670SZQ1 Keyboard Replacement: step 4, image 1 of 3 why! W670SZQ1 Keyboard Replacement: step 4, image 2 of 3 why! W670SZQ1 Keyboard Replacement: step 4, image 3 of 3
    • Once the bar hiding the fixing screws of the keyboard is unclipped we see the tip of the screwdriver.
    • Now find the 5 screws fixing the keyboard.
    • Unscrew the 5 screws.
  5. why! W670SZQ1 Keyboard Replacement: step 5, image 1 of 3 why! W670SZQ1 Keyboard Replacement: step 5, image 2 of 3 why! W670SZQ1 Keyboard Replacement: step 5, image 3 of 3
    • Now gently lift the keyboard.
    • Then appear the keyboard connection cable and the keyboard backlight cable
    • Start by unlocking the right latch of the connector securing the backlight cable.
  6. why! W670SZQ1 Keyboard Replacement: step 6, image 1 of 3 why! W670SZQ1 Keyboard Replacement: step 6, image 2 of 3 why! W670SZQ1 Keyboard Replacement: step 6, image 3 of 3
    • Then the one on the left.
    • Do the same with the left latch of the connector securing the main cable.
    • Then with the right latch of the connector fixing the main cable.
  7. why! W670SZQ1 Keyboard Replacement: step 7, image 1 of 1
    • Then remove the keyboard from its location.
To reassemble your device, Follow these instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 4
All Time: 210
