why! W670SZQ1 Remplacement Carte WLAN / Bluetooth
  1. why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, The Batteries: step 1, image 1 of 3 why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, The Batteries: step 1, image 2 of 3 why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, The Batteries: step 1, image 3 of 3
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, Access to Major Components: step 2, image 1 of 3 why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, Access to Major Components: step 2, image 2 of 3 why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, Access to Major Components: step 2, image 3 of 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Lift the bottom right cover with the iFixit Opening Tool.
    • Lift the lower left cover with the iFixit Opening Tool.
    • Finally clear the bottom cover completely to access the main components.
  3. why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, Carte WLAN / Bluetooth: step 3, image 1 of 3 why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, Carte WLAN / Bluetooth: step 3, image 2 of 3 why! W670SZQ1 Remplacement Carte WLAN / Bluetooth, Carte WLAN / Bluetooth: step 3, image 3 of 3
    • First disconnect one of the antenna connectors.
    • Then the other connector.
    • Unscrew the fixing screw with the Philips # 0 screwdriver. Then slightly lift the chipset and remove it from the mSATA connector.
TO REASSEMBLE YOUR DEVICE FOLLOW THE FOLLOWING INSTRUCTIONS IN REVERSE ORDER.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 117
