why! W670SZQ1 Replacement SSD Disk
  1. why! W670SZQ1 Replacement SSD Disk, The Batteries: step 1, image 1 of 3 why! W670SZQ1 Replacement SSD Disk, The Batteries: step 1, image 2 of 3 why! W670SZQ1 Replacement SSD Disk, The Batteries: step 1, image 3 of 3
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 Replacement SSD Disk, Access to Major Components: step 2, image 1 of 3 why! W670SZQ1 Replacement SSD Disk, Access to Major Components: step 2, image 2 of 3 why! W670SZQ1 Replacement SSD Disk, Access to Major Components: step 2, image 3 of 3
    • Using the Philips # 0 screwdriver, unscrew the 2 screws from the bottom cover.
    • Lift the bottom right cover with the iFixit Opening Tool.
    • Lift the lower left cover with the iFixit Opening Tool.
    • Finally clear the bottom cover completely to access the main components.
  3. why! W670SZQ1 Replacement SSD Disk, SSD disk: step 3, image 1 of 3 why! W670SZQ1 Replacement SSD Disk, SSD disk: step 3, image 2 of 3 why! W670SZQ1 Replacement SSD Disk, SSD disk: step 3, image 3 of 3
    • Unscrew the SSD fixing screw using the Philips # 0 screwdriver.
    • Lift the SSD.
    • Remove the SSD from its connector.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Israel is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 134
