why! W670SZQ1 Replacing the LCD screen
  1. why! W670SZQ1 Replacing the LCD screen, The Batteries: step 1, image 1 of 3 why! W670SZQ1 Replacing the LCD screen, The Batteries: step 1, image 2 of 3 why! W670SZQ1 Replacing the LCD screen, The Batteries: step 1, image 3 of 3
    • Unlock the lock latch on the left.
    • Unlock the lock latch on the right.
    • Remove the battery while holding the lock latch unlocked.
  2. why! W670SZQ1 Replacing the LCD screen, LCD screen: step 2, image 1 of 3 why! W670SZQ1 Replacing the LCD screen, LCD screen: step 2, image 2 of 3 why! W670SZQ1 Replacing the LCD screen, LCD screen: step 2, image 3 of 3
    • Start by locating the two screw caps on the left side of the screen.
    • Remove the lower screw cover.
    • Then the top screw cover.
  3. why! W670SZQ1 Replacing the LCD screen: step 3, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 3, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 3, image 3 of 3
    • Locate and then remove the first center screw on the top of the screen frame.
    • Then the second central cap on the top of the screen frame.
    • Then locate and remove the screw cap on the upper right side of the screen frame.
  4. why! W670SZQ1 Replacing the LCD screen: step 4, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 4, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 4, image 3 of 3
    • Then finally the bottom right screw cap of the screen frame.
    • Then unscrew the screws behind the screw caps, starting with the one at the bottom left of the frame.
    • Then at the top left.
  5. why! W670SZQ1 Replacing the LCD screen: step 5, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 5, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 5, image 3 of 3
    • Then the first central screw on the top edge of the frame.
    • Then the second central screw on the top edge of the frame.
    • Then the one in the upper right corner of the frame.
  6. why! W670SZQ1 Replacing the LCD screen: step 6, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 6, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 6, image 3 of 3
    • And finally the one on the lower right side of the frame.
    • Then gently use your nails.
    • To remove the frame from the LCD screen.
  7. why! W670SZQ1 Replacing the LCD screen: step 7, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 7, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 7, image 3 of 3
    • Unscrew the screws on the front of the LCD screen.
    • Next, unscrew the screws on the right side of the LCD screen, starting with the first one.
    • Then the second.
  8. why! W670SZQ1 Replacing the LCD screen: step 8, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 8, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 8, image 3 of 3
    • Then the third.
    • And finally the fourth.
    • Repeat these operations then on the left side of the screen starting with the first screw.
  9. why! W670SZQ1 Replacing the LCD screen: step 9, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 9, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 9, image 3 of 3
    • Then the second.
    • Then the third. .
  10. why! W670SZQ1 Replacing the LCD screen: step 10, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 10, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 10, image 3 of 3
    • Then flip the LCD screen.
    • Then appears the connector to which is attached the connection cable of the LCD.
    • Then peel off the tape covering the connector.
  11. why! W670SZQ1 Replacing the LCD screen: step 11, image 1 of 3 why! W670SZQ1 Replacing the LCD screen: step 11, image 2 of 3 why! W670SZQ1 Replacing the LCD screen: step 11, image 3 of 3
    • then remove the cable from its connector.
    • Once the cable is disconnected you can release the LCD screen.
to reassemble your device follow these instructions in reverse order.
Special thanks to these translators:
fr en
100%
irlanda is helping us fix the world! Want to contribute?
Start translating ›
Felice Suglia
31,100 Reputation
264 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 159
