Parts
GuidesAnswers
MacBook Pro Parts and Repair Kits
Fix what's broken. Upgrade what's not.
iFixit has you covered with parts, tools, and free repair guides. Repair your MBP laptop and install upgrades with confidence! All of our parts are tested to rigorous standards and backed by our industry-leading warranty.
Products
856 results
iFixit Thermal Paste
Forms a continuous, heat conductive layer between a processor and its heat sink. A new layer of thermal paste keeps your processor from overheating.
Number of reviews:49
$24.95
MacBook Pro 16" (2019) Battery
Replace a 8700 mAh battery compatible with the 2019 MacBook Pro 16" model A2141 laptop. 98.8 Watt Hours (Wh). 11.36 Volts (V). Fix Kit includes all tools and adhesive needed for a successful DIY repair.
$139.99
Apple MagSafe 1 AC Adapter
Replace a broken or damaged Apple MagSafe 1 AC 60W adapter with this part.
Number of reviews:26
Lifetime Guarantee
$29.99
Only 9 left in stock
MacBook Pro 14" (A2442, A2779, A2918) Battery
Replace a 6068 mAh A2519 battery compatible with the 2021 MacBook Pro 14" model A2442 or 2023 models A2779 and A2918 laptop. 69.9 Watt Hours (Wh). 11.46 Volts (V).
Number of reviews:14
$109.99
MacBook Pro 16" (2021 A2485) Battery
Replace a 8693 mAh A2527 battery compatible with the 2021 MacBook Pro 16" model A2485 laptop. 99.6 Watt Hours (Wh). 11.45 Volts (V).
Number of reviews:16
$109.99
MacBook Pro 15" Unibody (Early 2011-Mid 2012) Battery
Replace a 6730 mAh battery compatible with MacBook Pro 15" Unibody Early 2011 to Mid 2012 A1286 model laptops. 77.5 Watt Hours (Wh). 10.95 Volts (V). Part #661-5844. Battery model #A1382.
Number of reviews:236
$74.99
Universal Drive Adapter
Turn your current hard drive into an external drive with this adapter.
Number of reviews:38
Lifetime Guarantee
$24.99
MacBook Pro Unibody Lower Case Screw Set
Replace a stripped or missing screw securing the lower case of most Unibody model MacBook Pro laptops. The excluded models are the Late 2008 and Early 2009 15" MacBook Pro Unibody. These models have a separate battery door on the lower case. This
Number of reviews:119
Lifetime Guarantee
$12.99
MacBook Pro 13" Retina (Early 2015) Trackpad Cable
Replace the flex cable that connects the trackpad to the logic board compatible with the Early 2015 model A1502 MacBook Pro 13" Retina laptop. Part #821-00184.
Number of reviews:72
Lifetime Guarantee
$9.99
Only 3 left in stock
iFixit Buying Guide
