This teardown is not a repair guide. To repair your A-Solar Power Bank AL-200, use our service manual.
  1. A-Solar PowerBank AL-200 Teardown, A-Solar PowerBank AL-200 Teardown: step 1, image 1 of 2 A-Solar PowerBank AL-200 Teardown, A-Solar PowerBank AL-200 Teardown: step 1, image 2 of 2
    • There are three blue LEDs to show you the power in the battery.
    • There is also a handy LED to see what you are doing in the dark.
  2. A-Solar PowerBank AL-200 Teardown: step 2, image 1 of 3 A-Solar PowerBank AL-200 Teardown: step 2, image 2 of 3 A-Solar PowerBank AL-200 Teardown: step 2, image 3 of 3
    • The bottom of the device.
    • It's time for some prying. Take out the rubber plugs at the bottom of the device.
    • Remove the screws which are underneath the plugs.
  3. A-Solar PowerBank AL-200 Teardown: step 3, image 1 of 2 A-Solar PowerBank AL-200 Teardown: step 3, image 2 of 2
    • use a flathead screwdriver or a spudger to pry open the device.
    • Don't pry at the front of the device - there are a few hooks and you do not want to break them.
  4. A-Solar PowerBank AL-200 Teardown: step 4, image 1 of 1
    • A first glance at the inside: a big battery and the logic board.
    • There is a 1800 mAh battery in it.
    • There are two screws in the logic board, the battery is glued to the casing.
  5. A-Solar PowerBank AL-200 Teardown: step 5, image 1 of 2 A-Solar PowerBank AL-200 Teardown: step 5, image 2 of 2
    • The other side of the electronics.
    • And the logic board.
  6. A-Solar PowerBank AL-200 Teardown: step 6, image 1 of 1
    • And there it is: the A-Solar PowerBank AL-200 torn down.
    • It was easy to do.
storm
552 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 47
All Time: 5,405
