This teardown is not a repair guide. To repair your AVerMedia Live Streamer NEXUS AX310, use our service manual.
  1. AVerMedia NEXUS AX310 Teardown, Remove rubbers: step 1, image 1 of 2 AVerMedia NEXUS AX310 Teardown, Remove rubbers: step 1, image 2 of 2
    • Remove rubbers (red). They are pretty dense so to not worry to damage them. Do not remove label (blue) - it have hole under, but it is not a screw hole
  2. AVerMedia NEXUS AX310 Teardown, Screw remove: step 2, image 1 of 1
    • Remove 6 PH1 screws. Need to notice, that upper 3 screws are deep - so you need long thin screwdriver.
  3. AVerMedia NEXUS AX310 Teardown, Latches: step 3, image 1 of 3 AVerMedia NEXUS AX310 Teardown, Latches: step 3, image 2 of 3 AVerMedia NEXUS AX310 Teardown, Latches: step 3, image 3 of 3
    • Unclick latches using long side of credit card. I recomend this because latches are really strong and not flexible, so this wat to do this will help to keep them alive
    • You need to do this above rgb line
    • Do both sides and bottom, after that upper side will free itself.
    • Do not pull upper half of streamer as it connected to bottom with wires
  4. AVerMedia NEXUS AX310 Teardown, Bottom wire: step 4, image 1 of 2 AVerMedia NEXUS AX310 Teardown, Bottom wire: step 4, image 2 of 2
    • Lift bottom side and make colorful wire visible and acceseble
    • Unplug it. This part do not have any clips, so gust push it down
  5. AVerMedia NEXUS AX310 Teardown, Unplug screen wire: step 5, image 1 of 2 AVerMedia NEXUS AX310 Teardown, Unplug screen wire: step 5, image 2 of 2
    • Flip bottom half of streamer more and make display and touchscreen plumes visible
    • Remove black isolation (if you have it) on bottom pcb
    • Lift black lockers
    • Remove plumes
  6. AVerMedia NEXUS AX310 Teardown, Upper part screw remove: step 6, image 1 of 2 AVerMedia NEXUS AX310 Teardown, Upper part screw remove: step 6, image 2 of 2
    • Remove 6 PH1 screws on top
    • Im done on this, because my goal was to check any marks on screen. I think to fully remove top pcb you need to remove bottom parts of audio spinnerŅ‹ but i cannot do it
havrilyuk
158 Reputation
1 Guide authored
One Comment
It helpful! Thanks
ivas_andre - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 558
