This teardown is not a repair guide. To repair your AWEI BT Earbuds, use our service manual.
  1. AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: step 1, image 1 of 2 AWEI BT Earbuds & Receiver Teardown, Earbud Dissasembly: step 1, image 2 of 2
    • Remove Earbud Cushion
  2. AWEI BT Earbuds & Receiver Teardown, Secure Earbud for Separation: step 2, image 1 of 1
    • Secure Earbud End (eg:Vice)
  3. AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: step 3, image 1 of 2 AWEI BT Earbuds & Receiver Teardown, Separate Earbud Sections: step 3, image 2 of 2
    • Using Pliers Gently Twist & Pry Away Sections, Do Not Twist more than 3-4mm
  4. AWEI BT Earbuds & Receiver Teardown, Inspect Separated Earbud Internal Wiring: step 4, image 1 of 1
    • Inspect Earbud Wiring
  5. AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: step 5, image 1 of 3 AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: step 5, image 2 of 3 AWEI BT Earbuds & Receiver Teardown, Separate Receiver Housing: step 5, image 3 of 3
    • Using a small pick or pry tool, separate Receiver Housing. Each side is secured by 3 small fragile tabs. Use the space near the micro USB opening & carefully pry to separate the 3 tabs on the opposite side.
  6. AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: step 6, image 1 of 3 AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: step 6, image 2 of 3 AWEI BT Earbuds & Receiver Teardown, Inspect Receiver Internal Wiring: step 6, image 3 of 3
    • Carefully Separate the PCB to inspect the headphone's left & right earbud wiring. Cleaned up any broken connections by de-soldering, re-tinning wires & re-soldering to the PCB. Each side is labeled L + L - and R + R - the colored wire is positive and the bare wire is negative.
    • Assemble Unit in reverse order.
fugitiveALiEN
188 Reputation
1 Guide authored
My Techno Guy Member of My Techno Guy
Business
1 Member
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 13
All Time: 1,631
