This teardown is not a repair guide. To repair your Amazon Basics Alarm Clock, use our service manual.
  1. Amazon Basics Alarm Clock Teardown, Overview: step 1, image 1 of 3 Amazon Basics Alarm Clock Teardown, Overview: step 1, image 2 of 3 Amazon Basics Alarm Clock Teardown, Overview: step 1, image 3 of 3
    • Remove the 9 volt battery and unplug the alarm clock
  2. Amazon Basics Alarm Clock Teardown, Opening Case: step 2, image 1 of 2 Amazon Basics Alarm Clock Teardown, Opening Case: step 2, image 2 of 2
    • Remove the 4 screws and seperate the two halves
  3. Amazon Basics Alarm Clock Teardown, Remove top PCB: step 3, image 1 of 3 Amazon Basics Alarm Clock Teardown, Remove top PCB: step 3, image 2 of 3 Amazon Basics Alarm Clock Teardown, Remove top PCB: step 3, image 3 of 3
    • 4 screws are removed to release the top PCB, the screen and top PCB can then be removed. The speaker is permanently installed in the top and cannot be removed without unsoldering it and removing the glue.
  4. Amazon Basics Alarm Clock Teardown, Remove transformer: step 4, image 1 of 3 Amazon Basics Alarm Clock Teardown, Remove transformer: step 4, image 2 of 3 Amazon Basics Alarm Clock Teardown, Remove transformer: step 4, image 3 of 3
    • Transformer and wire strain relief are held in by 3 screws, when removed each part can be lifted out.
  5. Amazon Basics Alarm Clock Teardown, Final Disassembly: step 5, image 1 of 3 Amazon Basics Alarm Clock Teardown, Final Disassembly: step 5, image 2 of 3 Amazon Basics Alarm Clock Teardown, Final Disassembly: step 5, image 3 of 3
    • All buttons from top case lift out completing the disassembly. Without de-soldering the 9v battery connector and the speaker the top and bottom case halves are still connected.
Wieli
2,141 Reputation
13 Guides authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 69
All Time: 324
