This teardown is not a repair guide. To repair your Anker LC-90 Rechargeable Flashlight, use our service manual.
  1. Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: step 1, image 1 of 3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: step 1, image 2 of 3 Anker LC-90 Rechargeable Flashlight Teardown, Anker LC-90 Rechargeable Flashlight Teardown: step 1, image 3 of 3
    • Unscrew the battery cap
    • Remove battery
    • The cap is heavily tightened from the factory, therefore it may be necessary to use a rubber mat for added grip.
  2. Anker LC-90 Rechargeable Flashlight Teardown: step 2, image 1 of 1
    • Unscrew the lens holder as shown in the picture
  3. Anker LC-90 Rechargeable Flashlight Teardown: step 3, image 1 of 3 Anker LC-90 Rechargeable Flashlight Teardown: step 3, image 2 of 3 Anker LC-90 Rechargeable Flashlight Teardown: step 3, image 3 of 3
    • Slide the lens housing down, toward the base, to remove
    • Note that once the lens housing is pushed down the lens and reflector pop out.
  4. Anker LC-90 Rechargeable Flashlight Teardown: step 4, image 1 of 1
    • The Anker LC-90 is now tore down
Nick Wolfe
709 Reputation
2 Guides authored
Cal Poly, Team S18-G4, Livingston Winter 2018 Member of Cal Poly, Team S18-G4, Livingston Winter 2018
CPSU-LIVINGSTON-W18S18G4
4 Members
13 Guides authored
5 Comments
cannot buy parts or return
JULIA - Reply
have an l90 by anker
where can i get parts
seems to need new assembly where u plug in usb
JULIA - Reply
Have 3 LC90 flashlight with the same problems, switch stuck & intermittently works! Need 3 replacement cap/switches part #??
Ray Miller - Reply
Where can I find a replacement bulb assembly for an anker bolder flashlight?
richard pare sr - Reply
Thanks for the information. Took the flashlight battery out and then put in back in; seems to be working great for now!
Steve Moss - Reply
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 19
All Time: 3,966
