This teardown is not a repair guide. To repair your Apple DVI to ADC Adapter, use our service manual.
  1. Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: step 1, image 1 of 3 Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: step 1, image 2 of 3 Apple DVI to ADC Adapter Teardown, Remove Sticker Screw Cover: step 1, image 3 of 3
    • Turn the device upside down so that the information printed on the back is visible.
    • Carefully peel the sticker using a screwdriver from an edge. This will reveal two Phillips screws.
  2. Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: step 2, image 1 of 3 Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: step 2, image 2 of 3 Apple DVI to ADC Adapter Teardown, Bust the Plastic Housing Open: step 2, image 3 of 3
    • Begin to open from the cable side. Carefully lift the side up like you would a hinge. The clips should un-clip themselves.
    • There are plastic clips that hold the casing together on the other side.
  3. Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: step 3, image 1 of 3 Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: step 3, image 2 of 3 Apple DVI to ADC Adapter Teardown, Removing the Shielded PSU: step 3, image 3 of 3
    • Remove all four screws on the edges of the PSU.
    • To remove the last screw, remove the shielding tape.
    • Be careful not to pull on the PSU too hard. there is a connection to the logic board.
    • Carefully peel the shielding tape to release the PSU from it's place
  4. Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: step 4, image 1 of 3 Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: step 4, image 2 of 3 Apple DVI to ADC Adapter Teardown, Release the PSU and Deshield the Logic Board: step 4, image 3 of 3
    • Pull the shield towards the cable side and it should pop open. (Some force is required).
    • Disconnect the PSU connector.
    • PSU is free.
  5. Apple DVI to ADC Adapter Teardown, Removing the Logic Board: step 5, image 1 of 1
    • Unscrew the logic board and pull it out
alienozi
146 Reputation
1 Guide authored
One Comment
Great teardown and history lesson! I didn’t know what ADC was—a proprietary Apple interpretation of DVI. Apple hasn’t changed a bit, for better or worse. The world is a better place for it though :)
iEvan - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 36
All Time: 2,207
