Video Overview
This teardown is not a repair guide. To repair your Apple Vision Pro, use our service manual.
  1. Apple Vision Pro Chip ID, Logic board front: step 1, image 1 of 2 Apple Vision Pro Chip ID, Logic board front: step 1, image 2 of 2
    • Apple APL1109/339S01081E M2 octa-core applications processor & graphics processing unit
    • Micron MT62F1G64D8WT-031 XT:B 8 GB LPDDR5 SDRAM memory
    • Apple APL1W08/339S01186 R1 sensor coprocessor
    • Kioxia K5A4RC2097 256 GB NAND flash
    • Apple APL109C/343S00627 power management
    • Apple APL109D/343S00628 power management
    • Apple APL1004/343S00629 power management
  2. Apple Vision Pro Chip ID: step 2, image 1 of 1
    • Apple 338S00521-B0 power management
    • Texas Instruments LMK1C1104 clock buffer
    • Analog Devices LT8652S 8.5 A / 18 V dual channel synchronous step-down converter
    • Texas Instruments TPS62125 300 mA buck converter
    • Texas Instruments TPS61045 adjustable boost converter
    • onsemi FPF2895C current limit switch
    • Texas Instruments TPS70936 150 mA / 3.6 V LDO regulator
  3. Apple Vision Pro Chip ID, Logic board front connectivity chips: step 3, image 1 of 1
    • USI 339S01015 WiFi/Bluetooth module
  4. Apple Vision Pro Chip ID, Logic board back: step 4, image 1 of 2 Apple Vision Pro Chip ID, Logic board back: step 4, image 2 of 2
    • Analog Devices TMC5072 dual 2-phase stepper motor driver
    • Lattice Semiconductor ICE5LP4K iCE40 Ultra FPGA
    • Likely Cirrus Logic CS46L11 audio codec
    • Diodes Incorporated PI2DBS16212A 2:1 multiplexer/demultiplexer
    • Texas Instruments TMUX1575 quad SPDT analog switch
    • Texas Instruments TS5A23159 dual SPDT analog switch
    • Texas Instruments TPS62135 4 A step-down converter
  5. Apple Vision Pro Chip ID: step 5, image 1 of 1
    • Texas Instruments TLV6703 comparator w/ integrated reference
  6. Apple Vision Pro Chip ID, Charging board front: step 6, image 1 of 2 Apple Vision Pro Chip ID, Charging board front: step 6, image 2 of 2
    • This charging board is positioned in the battery pack.
    • STMicroelectronics STM32L4A6VG Arm Cortex-M4 microcontroller
    • GigaDevice GD25Q80E 1 MB serial NOR flash memory
    • Texas Instruments CD3217B13 USB type-C controller
    • Texas Instruments TPD4S311A USB type-C port protector
    • Texas Instruments TPS62180 6 A synchronous buck converter
    • Texas Instruments TPS62160 1 A step-down converter
  7. Apple Vision Pro Chip ID, Charging board front sensors: step 7, image 1 of 1
    • Bosch Sensortec accelerometer
  8. Apple Vision Pro Chip ID, Charging board back: step 8, image 1 of 2 Apple Vision Pro Chip ID, Charging board back: step 8, image 2 of 2
    • Renesas ISL9238C buck-boost battery charger
    • Renesas RAA489800 bidirectional buck-boost voltage regulator
  9. Apple Vision Pro Chip ID, Charging board back sensors: step 9, image 1 of 1
    • Texas Instruments TMP103A temperature sensor
    • Texas Instruments TMP103B temperature sensor
  10. Apple Vision Pro Chip ID, Right speaker board: step 10, image 1 of 2 Apple Vision Pro Chip ID, Right speaker board: step 10, image 2 of 2
    • Texas Instruments SN02776B0A audio amplifier
7 Comments
No ID of the sensor chips?
Quantum of solace - Reply
What do you think the Diodes Incorporated PI2DBS16212A 2:1 multiplexer/demultiplexer is for? What do you think the long module is at the bottom left of the main board?
Daniel De Sousa - Reply
What IC's control all the LEDs, cameras, etc? Are these in a module somewhere?
Sean Davis - Reply
I'm also waiting for ID of the sensor chips/modules. Are you going to update this site/article with more?
Fyo - Reply
Where’s four imu chip
nihao276720747 - Reply
Past 24 Hours: 12
Past 7 Days: 59
Past 30 Days: 259
All Time: 22,166
