This teardown is not a repair guide. To repair your Asus ZenWatch 3, use our service manual.
  1. Asus ZenWatch 3 Teardown, Let's begin: step 1, image 1 of 1
    • Tools needed T5 screwdriver
  2. Asus ZenWatch 3 Teardown, Band Removal: step 2, image 1 of 2 Asus ZenWatch 3 Teardown, Band Removal: step 2, image 2 of 2
    • Remove pins securing the band
  3. Asus ZenWatch 3 Teardown, Open the body: step 3, image 1 of 1
    • Remove the four screws
  4. Asus ZenWatch 3 Teardown: step 4, image 1 of 1
    • Pry open at the side near the rose gold ring
  5. Asus ZenWatch 3 Teardown: step 5, image 1 of 1
    • The battery would be automatically disconnected
  6. Asus ZenWatch 3 Teardown: step 6, image 1 of 1
    • Battery
  7. Asus ZenWatch 3 Teardown: step 7, image 1 of 1
    • Remove ribbons connected to the board
  8. Asus ZenWatch 3 Teardown: step 8, image 1 of 1
    • Complete disassembly
Reon
141 Reputation
1 Guide authored
20 Comments
I'm excited to find out if the middle button is actually a digital crown and whether or not there is NFC. This was built for wear 2.0 after all.
Joseph White - Reply
Is it possible to also see a picture of the chip side of the PCB? Would like to see how the 2100 is designed into the board
Jan Gaudestad - Reply
Does anybody know how the third button can be replaced? I lost it. Thank you in advance for any help.
splatdom - Reply
What should I do if the power button doesn’t work?
MichaelKing10or - Reply
I took mine apart for this very thing. The other buttons clearly click, but the middle button was kind of mushy. I don’t see a way to easily remove the button from the circuit board. However, in looking it over, I found that if the circuit board is pressed firmly while pressing the power button, it does get the thing to click. Upon reassembly, I found this to still be true. When the power button doesn’t work, if I squeeze the watch, face to back, and at the same time press the button, it makes contact.
Brodie Krause -
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 62
All Time: 14,586
