This teardown is not a repair guide. To repair your Audio-Technica ATH-M50x, use our service manual.
  1. Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: step 1, image 1 of 3 Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: step 1, image 2 of 3 Audio-Technica ATH-M50x Teardown, Remove Foam Earpads: step 1, image 3 of 3
    • Unfold the headphones face up for easy access to the Foam Earpads.
    • Insert index finger underneath foam, pinch foam between thumb and index and slowly ease the compression fitting out of its track.
    • Repeat same process for right Earpad.
  2. Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: step 2, image 1 of 3 Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: step 2, image 2 of 3 Audio-Technica ATH-M50x Teardown, Remove Speaker Plate: step 2, image 3 of 3
    • Remove four J1 screws.
    • Carefully lift plate to avoid putting any strain on the internal wiring. Note that connections are soldered.
    • Make sure to free the speaker wire from W shaped spring before setting the Speaker plate next to the headphone assembly.
  3. Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: step 3, image 1 of 3 Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: step 3, image 2 of 3 Audio-Technica ATH-M50x Teardown, Remove Speaker Housing and Speaker: step 3, image 3 of 3
    • Unscrew the three remaining J1 screws.
    • Lift speaker retainer away from speaker.
    • The speaker now comes away easily from the speaker plate.
  4. Audio-Technica ATH-M50x Teardown, Repeat steps 2 and 3 for Left Earpiece: step 4, image 1 of 1
    • To remove speakers will require soldering skill.
Broske
181 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 46
Past 30 Days: 182
All Time: 9,778
