This teardown is not a repair guide. To repair your Beyer Dynamic DT290, use our service manual.
  1. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the Ear Pad: step 1, image 1 of 1
    • The ear pad is held to the ear piece by 4 plastic clips. Gently pull the ear pad away from the ear piece to remove.
  2. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the Speaker: step 2, image 1 of 1
    • Remove the speaker driver by removing the screws above and below.
  3. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove white plastic clip: step 3, image 1 of 1
    • Remove the white plastic clip with a plastic prying tool. It's likely that it is stuck down with some low tack adhesive.
  4. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove Blue Clip: step 4, image 1 of 1
    • By pushing the blue clips towards the centre with a prying tool or something similar, the microphone boom arm is then released from the body of the ear piece.
  5. Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the boom arm: step 5, image 1 of 3 Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the boom arm: step 5, image 2 of 3 Beyer Dynamic DT280/DT290 Microphone Teardown, Remove the boom arm: step 5, image 3 of 3
    • To remove the boom arm, it must be de-soldered from the PCB
Chris Moore
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 12
All Time: 728
