This teardown is not a repair guide. To repair your Bluesmart Black Edition, use our service manual.
  1. Bluesmart Black Edition Teardown, Open Suitcase: step 1, image 1 of 3 Bluesmart Black Edition Teardown, Open Suitcase: step 1, image 2 of 3 Bluesmart Black Edition Teardown, Open Suitcase: step 1, image 3 of 3
    • Open the suitcase.
  2. Bluesmart Black Edition Teardown, Turn off suitcase: step 2, image 1 of 3 Bluesmart Black Edition Teardown, Turn off suitcase: step 2, image 2 of 3 Bluesmart Black Edition Teardown, Turn off suitcase: step 2, image 3 of 3
    • Open this switch cover and power off the device.
  3. Bluesmart Black Edition Teardown, Unzip inner lining: step 3, image 1 of 2 Bluesmart Black Edition Teardown, Unzip inner lining: step 3, image 2 of 2
    • Slide the zipper this direction
  4. Bluesmart Black Edition Teardown, Lift away inner lining: step 4, image 1 of 1
    • Lift it out of the way.
  5. Bluesmart Black Edition Teardown: step 5, image 1 of 1
    • Unscrew the 4 large Phillips screws
    • Unscrew the 8 smaller Phillips screws
  6. Bluesmart Black Edition Teardown: step 6, image 1 of 1
    • Remove these 2 large Phillips screws
    • These screws are different than the ones from the previous step. Keep them separate.
  7. Bluesmart Black Edition Teardown, Check: step 7, image 1 of 1
    • Make sure they are all screws are completely removed before proceeding
  8. Bluesmart Black Edition Teardown: step 8, image 1 of 2 Bluesmart Black Edition Teardown: step 8, image 2 of 2
    • Stand the suitcase up
    • Pull up on the handle
    • Only pull as far as shown in the photo, or you will end up breaking cables.
  9. Bluesmart Black Edition Teardown: step 9, image 1 of 2 Bluesmart Black Edition Teardown: step 9, image 2 of 2
    • Carefully disconnect the 3 cables connecting the circuit board to the suitcase.
    • Pull by the connector, not by the wires.
  10. Bluesmart Black Edition Teardown: step 10, image 1 of 1
    • We can now see the bottom of the circuit board. It has a QR code with a serial number or MAC address.
    • It also has a SIM card slot.
  11. Bluesmart Black Edition Teardown, SIM Removal: step 11, image 1 of 3 Bluesmart Black Edition Teardown, SIM Removal: step 11, image 2 of 3 Bluesmart Black Edition Teardown, SIM Removal: step 11, image 3 of 3
    • To remove the SIM card, use your nail to slide the metal bracket back
    • Then, flip the bracket, and slide out the SIM card.
    • Make sure the SIM card is all the way back in the bracket before closing.
  12. Bluesmart Black Edition Teardown, Battery Compartment: step 12, image 1 of 3 Bluesmart Black Edition Teardown, Battery Compartment: step 12, image 2 of 3 Bluesmart Black Edition Teardown, Battery Compartment: step 12, image 3 of 3
    • To replace the battery, remove these 4 Phillips screws.
  13. Bluesmart Black Edition Teardown, Switch Removal: step 13, image 1 of 1
    • To remove the power switch, remove these 2 small Phillips screws.
    • You will need a smaller screwdriver
  14. Bluesmart Black Edition Teardown: step 14, image 1 of 3 Bluesmart Black Edition Teardown: step 14, image 2 of 3 Bluesmart Black Edition Teardown: step 14, image 3 of 3
    • After removing the screws holding circuit board in place, you flip it down.
    • Cellular/GPS Antennas
    • Empty USB header used in the Bluesmart One
    • Bluetooth module (CC2541)
    • Microcontroller - ABOV 96F4548L (48KB ROM, 2KB EEPROM, 256B iRAM, 1.5KB xRAM)
    • Cellular/GPS Module (ZTE MF206A)
9021007
4,599 Reputation
25 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 103
All Time: 1,324
