This teardown is not a repair guide. To repair your Bosch GBA Battery 14.4V 1.5Ah, use our service manual.
  1. Bosch GBA Battery 14.4V 1.5Ah Teardown, Introduction: step 1, image 1 of 1
    • Here we have our (almost) new Bosch battery 14,4V for cordless drill. Simple and stylish design, with Bosch Company logo on the side and necessary number identifier. The top part is universal Bosch battery socket, which will fit all cordless tools of this voltage type.
  2. Bosch GBA Battery 14.4V 1.5Ah Teardown, Disassembly: step 2, image 1 of 2 Bosch GBA Battery 14.4V 1.5Ah Teardown, Disassembly: step 2, image 2 of 2
    • Bosch battery is held together by 4 combo screws, which will fit both flat and torx screwdrivers. Flat screwdriver is used in this particular case.
  3. Bosch GBA Battery 14.4V 1.5Ah Teardown: step 3, image 1 of 3 Bosch GBA Battery 14.4V 1.5Ah Teardown: step 3, image 2 of 3 Bosch GBA Battery 14.4V 1.5Ah Teardown: step 3, image 3 of 3
    • Once screws are removed, we´ll flip the battery back and gently remove the upper lid, revealing the surprising insides.
    • Third part is a battery pack holder, which holds 4 "18650" Li-ion cells together, including a tiny PCB with metal connector claws and two resistors. We´ll gently lift the pack and put it to side. Care must be disciplined, to avoid short-circuiting the powerful cells.
  4. Bosch GBA Battery 14.4V 1.5Ah Teardown, Upper lid disassembly: step 4, image 1 of 3 Bosch GBA Battery 14.4V 1.5Ah Teardown, Upper lid disassembly: step 4, image 2 of 3 Bosch GBA Battery 14.4V 1.5Ah Teardown, Upper lid disassembly: step 4, image 3 of 3
    • Upper lid houses a curious release mechanism with 3 parts total.
    • The red push button that slid inside and applies force to dark black blocker, which is poking from the lid.
    • Nothing is holding it in place, we can easily remove it by lifting and picking it up.
    • Black blocker is held in place by two pieces of plastic on both sides, but can be removed easily and without damage.
  5. Bosch GBA Battery 14.4V 1.5Ah Teardown, Lower Lid: step 5, image 1 of 1
    • Lower lid hides no surprises, just ergonomically shaped bottom which holds the li-ion cells nicely fit in place.
  6. Bosch GBA Battery 14.4V 1.5Ah Teardown, PCB in detail: step 6, image 1 of 2 Bosch GBA Battery 14.4V 1.5Ah Teardown, PCB in detail: step 6, image 2 of 2
    • The PCB houses 5 spring jaws total, two on sides are GND and VCC, inner 3 are connected with resistors and are used to monitor battery temperature during workload and charging.
    • Interesting enough, different jaw is used by battery and by cordless drill, only the centerpiece is common in both.
  7. Bosch GBA Battery 14.4V 1.5Ah Teardown, Remaining details: step 7, image 1 of 3 Bosch GBA Battery 14.4V 1.5Ah Teardown, Remaining details: step 7, image 2 of 3 Bosch GBA Battery 14.4V 1.5Ah Teardown, Remaining details: step 7, image 3 of 3
    • On these last photos we can see the way these 4 li-ion cells are connected. Spot welded in two places. Four 3,7V cells in series will produce the 14,4V as advertised.
    • There is also a temperature probe, which most certainly is a thermal resistor, freely stuck between two inner cells.
    • There is no control board in the battery cell, which really improves the durability. The function of control board was moved into the charger and the drill, but that doesn´t affect the price of these battery packs.
Saren Aurelius
434 Reputation
2 Guides authored
2 Comments
Very useful information.I have just been given this battery plus drill. Unfortunately the battery was useless had been left in the rain or dropped into water and left, so after looking at this site have been able so Far to dismantle the battery pack and seen the batteries totally destroyed. Luckily I have some samsung 18650s that I can replace and rebuild. With a little luck will be using it soon. Will comment on final rebuild and testing. Thank you.
steve miller - Reply
What is price this batrry…??
TRS - Reply
Past 24 Hours: 7
Past 7 Days: 22
Past 30 Days: 129
All Time: 11,355
