Bosch Pro Animal BSGL5ZOO2 Teardown
  1. Bosch Pro Animal BSGL5ZOO2 Teardown, Remove hose: step 1, image 1 of 2 Bosch Pro Animal BSGL5ZOO2 Teardown, Remove hose: step 1, image 2 of 2
    • Disconnect the power plug from the mains.
    • Remove the hose by pressing the two catches on the sides.
  2. Bosch Pro Animal BSGL5ZOO2 Teardown, Remove dust bag and filter: step 2, image 1 of 3 Bosch Pro Animal BSGL5ZOO2 Teardown, Remove dust bag and filter: step 2, image 2 of 3 Bosch Pro Animal BSGL5ZOO2 Teardown, Remove dust bag and filter: step 2, image 3 of 3
    • Remove residue bag G8.
    • Remove HEPA high efficiency hygiene filter 579496 VZ154HFB
    • Remove motor protection filter 578863 VZ01MSF
  3. Bosch Pro Animal BSGL5ZOO2 Teardown, Remove Start-button: step 3, image 1 of 2 Bosch Pro Animal BSGL5ZOO2 Teardown, Remove Start-button: step 3, image 2 of 2
    • Use the spudger to lever the start button upwards from the front and remove it.
  4. Bosch Pro Animal BSGL5ZOO2 Teardown, Remove screws: step 4, image 1 of 2 Bosch Pro Animal BSGL5ZOO2 Teardown, Remove screws: step 4, image 2 of 2
    • Loosen the 6 screws with the screwdriver.
    • Remove front grip.
  5. Bosch Pro Animal BSGL5ZOO2 Teardown, Remove top side of housing: step 5, image 1 of 2 Bosch Pro Animal BSGL5ZOO2 Teardown, Remove top side of housing: step 5, image 2 of 2
    • Lift the top of the housing from the handle side
    • Remove the top of the housing towards the rear.
  6. Bosch Pro Animal BSGL5ZOO2 Teardown, Remove motor cover: step 6, image 1 of 3 Bosch Pro Animal BSGL5ZOO2 Teardown, Remove motor cover: step 6, image 2 of 3 Bosch Pro Animal BSGL5ZOO2 Teardown, Remove motor cover: step 6, image 3 of 3
    • Remove motor cover towards the back.
    • Carefully remove the circuit board from the guides of the cable drum.
    • The motor is now accessible.
Repeat the steps in reverse order to reassemble your device.
2 other people completed this guide.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
hainzy
5,673 Reputation
27 Guides authored
German Translators Member of German Translators
Community
28 Members
808 Guides authored
2 Comments
Danke!! War sehr hilfreich :-))
J B - Reply
Past 24 Hours: 4
Past 7 Days: 26
Past 30 Days: 115
All Time: 1,144
