This teardown is not a repair guide. To repair your Brother MFC-240C, use our service manual.
  1. Brother MFC-240C Teardown, Brother MFC-240C Teardown: step 1, image 1 of 3 Brother MFC-240C Teardown, Brother MFC-240C Teardown: step 1, image 2 of 3 Brother MFC-240C Teardown, Brother MFC-240C Teardown: step 1, image 3 of 3
    • Completely lift up scanner portion of printer and detach visible USB chord.
  2. Brother MFC-240C Teardown: step 2, image 1 of 3 Brother MFC-240C Teardown: step 2, image 2 of 3 Brother MFC-240C Teardown: step 2, image 3 of 3
    • Use flat head screwdriver to pry tabbed panel off.
  3. Brother MFC-240C Teardown: step 3, image 1 of 3 Brother MFC-240C Teardown: step 3, image 2 of 3 Brother MFC-240C Teardown: step 3, image 3 of 3
    • Gently lift up ribbon cable and pull it through holder then remove ribbon cable from its track.
  4. Brother MFC-240C Teardown: step 4, image 1 of 3 Brother MFC-240C Teardown: step 4, image 2 of 3 Brother MFC-240C Teardown: step 4, image 3 of 3
    • Using a flat head screwdriver, remove the 2nd tabbed panel.
  5. Brother MFC-240C Teardown: step 5, image 1 of 3 Brother MFC-240C Teardown: step 5, image 2 of 3 Brother MFC-240C Teardown: step 5, image 3 of 3
    • Remove the 4 plugs and unscrew ground-wire then place the plugs to the side.
  6. Brother MFC-240C Teardown: step 6, image 1 of 2 Brother MFC-240C Teardown: step 6, image 2 of 2
    • Using your screwdriver press down on the tab as shown. This allows the hinge to be removed from the printing body as seen in photo.
  7. Brother MFC-240C Teardown: step 7, image 1 of 3 Brother MFC-240C Teardown: step 7, image 2 of 3 Brother MFC-240C Teardown: step 7, image 3 of 3
    • Extend scanner assembly completely to remove scanner portion.
  8. Brother MFC-240C Teardown: step 8, image 1 of 2 Brother MFC-240C Teardown: step 8, image 2 of 2
    • After removing the scanner assembly, place it on its head. Remove the hinge and 4 screws from the lower scanner portion using Philips-head screwdriver.
  9. Brother MFC-240C Teardown: step 9, image 1 of 3 Brother MFC-240C Teardown: step 9, image 2 of 3 Brother MFC-240C Teardown: step 9, image 3 of 3
    • Place on opposite face, and gently pry upper and lower scanner portions apart. Remove the 4 plugs from the lower scanner portion.
  10. Brother MFC-240C Teardown: step 10, image 1 of 3 Brother MFC-240C Teardown: step 10, image 2 of 3 Brother MFC-240C Teardown: step 10, image 3 of 3
    • To remove image sensor, detach the wire strip and pull it out. Remove the two springs that are under the image sensor after its removal.
  11. Brother MFC-240C Teardown: step 11, image 1 of 3 Brother MFC-240C Teardown: step 11, image 2 of 3 Brother MFC-240C Teardown: step 11, image 3 of 3
    • To remove the belt, first place the image sensor to the side then press down on the gear base to loosen belt and remove from the gear.
  12. Brother MFC-240C Teardown: step 12, image 1 of 3 Brother MFC-240C Teardown: step 12, image 2 of 3 Brother MFC-240C Teardown: step 12, image 3 of 3
    • Remove the 3 highlighted screws. For the gear driven by the motor, press the tab in highlighted gear to remove set gear. For the gear that was attached to belt, remove C-clip to remove gear then pull the last gear off.
  13. Brother MFC-240C Teardown: step 13, image 1 of 2 Brother MFC-240C Teardown: step 13, image 2 of 2
    • After the removing gears, lift up on the retained end of metal rod and pull out the other side.
  14. Brother MFC-240C Teardown: step 14, image 1 of 2 Brother MFC-240C Teardown: step 14, image 2 of 2
    • Once the rod has been removed, remove the metal plate in which the gears were sitting then take out the motor.
Andrew Adcock
131 Reputation
1 Guide authored
2 Comments
This is only the scanner part? where is the printer part for teardown?
rene moret - Reply
excellent guide, i like to know how to clean the head assembly and the the little hose that guides the ink to the head
alex jaimes - Reply
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 17
All Time: 5,042
