Introduction
this 60$ phone has more repairability than meets the eye
Today we will be tearing it down to see how much we can repair it.
We first need to take off the back cover and remove the battery. I used a coin to remove the back. its important to keep this screw tight for waterproofing.
AFTER REMOVING THE SCREWS, THE PHONE WILL NO LONGER BE WATERPROOF. This is because there are tiny gaskets around the screws to ensure its ip68 rating.
remove the 12 screws holding on the back. It should come off without any resistance because there is no clips
after we remove the back we have an optional part to take out. its the vibration motor. use tweezers or your fingers to remove it from the back
wow look at all those connectors. even the usbc is on its own easily replacable board!
remove all the connectors marked in blue.
just gently lift it up and take it out. after removing the heat shields we get to see the soc and the storage, as well as what I think is the modem.
there is a rubber cover on top of the unit that protects it. removing this shows another set of screws and a hard plastic cover
its not glued down or anything, just be careful to not get your paw prints on it
the front and back cameras come out pretty easy. be careful with the rear camera as there is some glue holding it down. using some ipa can help.
the board is taped down but doesnt put up a fight when you remove it with a pry tool.
at first I didn't think that the screen could be taken out. this was incorrect. after using my 3d printer (you can use your own method) to heat up the screen. from there I used ifixit picks to carefully pry the screen off
although the s22 is designed competently, there appears to be little to no repair parts available. the only place I was able to find that sells repair parts is in India and does not ship outside India. here is the website
4 Comments
really apreciate the teardown, thanks william:)
Er zal wel ijzer inzitten, zo zwaar.
This is very helpful. Thanks
Hi William, I don't suppose you remember if there was a wire connector near the hinge to make the upper speaker and camera work? I have this phone everything else works fine but the speaker you listen to when on a call doesn't work and the top camera as well. I was hoping it would be a simple fix like a loose connector
