This teardown is not a repair guide. To repair your Electronics, use our service manual.
  1. CCI Smart Strip 04941 Teardown, CCI Smart Strip 04941 Teardown: step 1, image 1 of 1
    • The Assembled Product, unplugged from wall
  2. CCI Smart Strip 04941 Teardown: step 2, image 1 of 2 CCI Smart Strip 04941 Teardown: step 2, image 2 of 2
    • Turn Smart Strip upside down and locate four screw holes in corners
    • Unscrew four corner screws with #0 Phillips Screwdriver
  3. CCI Smart Strip 04941 Teardown: step 3, image 1 of 2 CCI Smart Strip 04941 Teardown: step 3, image 2 of 2
    • Locate four latch slots in case
    • Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
  4. CCI Smart Strip 04941 Teardown: step 4, image 1 of 2 CCI Smart Strip 04941 Teardown: step 4, image 2 of 2
    • Take two halves of case apart with your hands
  5. CCI Smart Strip 04941 Teardown: step 5, image 1 of 1
    • Lift Ground Copper Strip upward off of power plugs by hand
  6. CCI Smart Strip 04941 Teardown: step 6, image 1 of 2 CCI Smart Strip 04941 Teardown: step 6, image 2 of 2
    • Locate latch securing power plugs to bottom of case
    • Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
  7. CCI Smart Strip 04941 Teardown: step 7, image 1 of 2 CCI Smart Strip 04941 Teardown: step 7, image 2 of 2
    • Lift power plugs out of bottom of case along with circuit assembly
nils smith
194 Reputation
1 Guide authored
2 Comments
This is great! Thanks so much!
nils smith - Reply
that awesome and i like how it fix
Joseph donkor - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 53
All Time: 1,949
