This teardown is not a repair guide. To repair your Electronics, use our service manual.
  1. CCI Smart Strip 04941 Teardown, CCI Smart Strip 04941 Teardown: step 1, image 1 of 1
    • The Assembled Product, unplugged from wall
  2. CCI Smart Strip 04941 Teardown: step 2, image 1 of 2 CCI Smart Strip 04941 Teardown: step 2, image 2 of 2
    • Turn Smart Strip upside down and locate four screw holes in corners
    • Unscrew four corner screws with #0 Phillips Screwdriver
  3. CCI Smart Strip 04941 Teardown: step 3, image 1 of 2 CCI Smart Strip 04941 Teardown: step 3, image 2 of 2
    • Locate four latch slots in case
    • Use 2.4mm Slotted Screwdriver, put tip into center of slot, with tip on outer edge of slot, and press inward
  4. CCI Smart Strip 04941 Teardown: step 4, image 1 of 2 CCI Smart Strip 04941 Teardown: step 4, image 2 of 2
    • Take two halves of case apart with your hands
    Really cool teardown...
    Is there a reason why you decided to do one on a power strip?
    FYI: there's absolutely NO sarcasm here. I'm always looking to add to my little of projects and this may have triggered and Idea
    If you don't mind sharing, why did this come to mind. Plesse, I don't need specifics. It just got me thinking of using this method to make a pretty nice expanded powerstrip that I desperately need, but don't want to pay over $120+ for 2 or more of the pricey ones, even though a surge protector would be nice (sorry I don't know if yours does, I skim thru fast when I read).
    Thank you!
    E
    es1101 - Reply
  5. CCI Smart Strip 04941 Teardown: step 5, image 1 of 1
    • Lift Ground Copper Strip upward off of power plugs by hand
  6. CCI Smart Strip 04941 Teardown: step 6, image 1 of 2 CCI Smart Strip 04941 Teardown: step 6, image 2 of 2
    • Locate latch securing power plugs to bottom of case
    • Using slotted 2.4mm screwdriver, pry latch away from power plugs to loosen power plugs
  7. CCI Smart Strip 04941 Teardown: step 7, image 1 of 2 CCI Smart Strip 04941 Teardown: step 7, image 2 of 2
    • Lift power plugs out of bottom of case along with circuit assembly
nils smith
194 Reputation
1 Guide authored
2 Comments
This is great! Thanks so much!
nils smith - Reply
that awesome and i like how it fix
Joseph donkor - Reply
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 53
All Time: 1,949
