This teardown is not a repair guide. To repair your Commodore 1341 Joystick, use our service manual.
  1. Commodore 1341 Joystick Teardown, Commodore 1341 Joystick Teardown: step 1, image 1 of 1
    • Introduced in 1984, the Commodore 1341 joystick was designed for use with the Commodore range of computers including the Commodore 64, 128, VIC20 and Commodore Plus4.
    • This joystick connects to the retro computers using a 9 pin connection.
  2. Commodore 1341 Joystick Teardown: step 2, image 1 of 3 Commodore 1341 Joystick Teardown: step 2, image 2 of 3 Commodore 1341 Joystick Teardown: step 2, image 3 of 3
    • The joystick is held together by five phillips head screws. One screw is located on the handle and the remaining four are under the base.
    • Once the screws have been removed you can pry the case apart using a flat head screw driver. Just be careful with the base as it is spring loaded and it can fly apart quite easily.
  3. Commodore 1341 Joystick Teardown: step 3, image 1 of 3 Commodore 1341 Joystick Teardown: step 3, image 2 of 3 Commodore 1341 Joystick Teardown: step 3, image 3 of 3
    • You will need to desolder the fire button cables from the board.
    • Pry the case open but watch for the spring. There is also a rubber bung that sits beneath the black rocker shaft.
    • Desolder the cables from the main joystick board and remove all of the components.
    • Now you are ready to clean all of the joystick components and reassemble.
Andy Marsh
118 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 21
All Time: 7,185
