This teardown is not a repair guide. To repair your MP3 Player, use our service manual.
  1. Cowon iAudio 7 8GB Teardown, Cowon iAudio 7 8GB Teardown: step 1, image 1 of 1
    • The device in original condition.
  2. Cowon iAudio 7 8GB Teardown: step 2, image 1 of 1
    • Removed the back of the case and the PCB screws. I had to drill open one of the case screws as it was stuck.
  3. Cowon iAudio 7 8GB Teardown: step 3, image 1 of 2 Cowon iAudio 7 8GB Teardown: step 3, image 2 of 2
    • All parts disassembled. Second photo shows back side of the PCB.
    • As we can see, the device contains two Samsung 4GB flash chips along with a K4M28163PH-BG75 memory controller.
    • A Telechips TCC771L as main CPU.
    • A PCF50606HN battery/power management chip.
[deleted]
210 Reputation
1 Guide authored
3 Comments
2011music my songs
Tong Thao - Reply
Hi! Could you, please, say what the type of display is there?
tikhonte - Reply
If anybody needs a new battery, try this: 3.7V polymer lithium battery 503060 or 053060
The number means the dimensions (5 x 30 x 60mm) The first number is often in 1/10mm
You’d need to solder the original cable to the battery or cables though.
Maybe you want to leave a comment here if this was helpful: adahnsplace.blogspot.com
Endre Sutus - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 4,424
