This teardown is not a repair guide. To repair your Toaster, use our service manual.
  1. Cuisinart 4-Slice Tandem Toaster Teardown, Cuisinart 4-Slice Tandem Toaster Teardown: step 1, image 1 of 1
    • This Cuisinart Toaster's technical highlights include:
    • Tandem, 2-slot toaster
    • 1½" wide toasting slots
    • Function control dial
    • Bagel, Defrost and Reheat selections
    • Blue LED shade control with large, easy-to-read numbers
    • 2 or 4 slice button; cancel button
  2. Cuisinart 4-Slice Tandem Toaster Teardown: step 2, image 1 of 2 Cuisinart 4-Slice Tandem Toaster Teardown: step 2, image 2 of 2
    • Unplug the toaster prior to teardown.
    • On the bottom of the toaster, unscrew the 4 Torx screws (using a screw driver)
  3. Cuisinart 4-Slice Tandem Toaster Teardown: step 3, image 1 of 3 Cuisinart 4-Slice Tandem Toaster Teardown: step 3, image 2 of 3 Cuisinart 4-Slice Tandem Toaster Teardown: step 3, image 3 of 3
    • Pull the press handle down and away from the toaster to disconnect the body.
    • Lift up the body of the toaster.
  4. Cuisinart 4-Slice Tandem Toaster Teardown: step 4, image 1 of 1
    • Pull the pin header cable to disconnect the body of the toaster from the main assembly unit.
  5. Cuisinart 4-Slice Tandem Toaster Teardown: step 5, image 1 of 3 Cuisinart 4-Slice Tandem Toaster Teardown: step 5, image 2 of 3 Cuisinart 4-Slice Tandem Toaster Teardown: step 5, image 3 of 3
    • Remove the 5 Torx screws to detach the heating unit from the bottom of the toaster unit.
  6. Cuisinart 4-Slice Tandem Toaster Teardown: step 6, image 1 of 3 Cuisinart 4-Slice Tandem Toaster Teardown: step 6, image 2 of 3 Cuisinart 4-Slice Tandem Toaster Teardown: step 6, image 3 of 3
    • Using a plastic opening tool, carefully pry open the metal casing underneath the toaster.
  7. Cuisinart 4-Slice Tandem Toaster Teardown: step 7, image 1 of 3 Cuisinart 4-Slice Tandem Toaster Teardown: step 7, image 2 of 3 Cuisinart 4-Slice Tandem Toaster Teardown: step 7, image 3 of 3
    • Remove the screws to detach controls from the plastic shell of the toaster.
  8. Cuisinart 4-Slice Tandem Toaster Teardown: step 8, image 1 of 1
    • Interior of the user control interface
  9. Cuisinart 4-Slice Tandem Toaster Teardown: step 9, image 1 of 1
    • Remove the soldered wire that is hooked to each part of the end plate assembly.
  10. Cuisinart 4-Slice Tandem Toaster Teardown: step 10, image 1 of 2 Cuisinart 4-Slice Tandem Toaster Teardown: step 10, image 2 of 2
    • Heating Unit
  11. Cuisinart 4-Slice Tandem Toaster Teardown: step 11, image 1 of 1
    • This is the Circuit Board used for controlling each subsystem of the toaster.
    • The integrated circuit marked 4541 contains an oscillator which oscillates at some hundreds or thousands of oscillations per second, the speed being determined by the browning setting. It also contains a binary counter which can count up to 65,536.
    • The integrated circuit marked 4066 contains several logic gates which select the count value required for normal, defrost or reheat.
    • During the count, the logic gates supply a small current to the transistor, causing it to energise the electromagnet. At the end of the selected count, the logic gates switch this current off and the transistor de-energises the electromagnet.
    • While energised, the electromagnet holds the lever down. When the current is switched off the lever is released and the spring pops the toast up.
    • Toasters of this age frequently use these "4000-series" integrated circuits as they can run off a wide range of supply voltages. Newer toasters use a microcontroller (essentially a simple micro computer) as this is more flexible in its functions and can also easily drive LEDs to show you what the toaster is doing.
  12. Cuisinart 4-Slice Tandem Toaster Teardown: step 12, image 1 of 1
    • Main Assembly Unit
  13. Cuisinart 4-Slice Tandem Toaster Teardown: step 13, image 1 of 1
    • Main Element Assembly
    • Crumb Tray with Power Cord
    • Circuitry with Heating Component
    • User Control Interface with Buttons
    • Press Handle Spring
Lucas Tintikakis
133 Reputation
1 Guide authored
EE460 UNO Member of EE460 UNO
Community
2 Members
8 Guides authored
3 Comments
Have this broken device and would be glad to us this demonstration to fix it!
Robert Scherer - Reply
Thanks for this great post-up. Saved me a lot of time not having to figure out the disassembly. Hope my comments will further help others trying to do the same.
Cheers!
Keith
K Lynch - Reply
Muy detallado desmontaje felicitaciones
Carlos López (España - Spain) - Reply
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 42
All Time: 6,272
