This teardown is not a repair guide. To repair your D-link DI-524, use our service manual.
  1. D-link DI-524 Teardown, Overview: step 1, image 1 of 3 D-link DI-524 Teardown, Overview: step 1, image 2 of 3 D-link DI-524 Teardown, Overview: step 1, image 3 of 3
    • This is the router, in all of its 12 year old glory.
  2. D-link DI-524 Teardown, Opening it up: step 2, image 1 of 3 D-link DI-524 Teardown, Opening it up: step 2, image 2 of 3 D-link DI-524 Teardown, Opening it up: step 2, image 3 of 3
    • First of, remove the antenna by simply unscrewing it.
    • With that done, flip the router over and remove the 2 screws marked out in orange (pic 2).
    • Then simply flip the router back over and lift up the top plastic.
  3. D-link DI-524 Teardown, Removing the board: step 3, image 1 of 3 D-link DI-524 Teardown, Removing the board: step 3, image 2 of 3 D-link DI-524 Teardown, Removing the board: step 3, image 3 of 3
    • With the plastic removed, we get a look at the board itself. Now remove the two other screws at the back (also marked out in orange).
    • Before being able to lift the whole board out, you will also have to unscrew a nut where the antenna was attached to. This can easily be done with a pair of pliers.
    • With that done, simply pull the connector out and lift the border 'up and out'.
  4. D-link DI-524 Teardown, The chips: step 4, image 1 of 3 D-link DI-524 Teardown, The chips: step 4, image 2 of 3 D-link DI-524 Teardown, The chips: step 4, image 3 of 3
    • This is simply a better look at the board chips. If anone reading this knows specifically what they are, feel free to comment and I will add the information.
    • (There is also one more chip but Ifiixit allows only 3 pictures)
  5. D-link DI-524 Teardown, The lone metal clip: step 5, image 1 of 2 D-link DI-524 Teardown, The lone metal clip: step 5, image 2 of 2
    • The last piece of the router is this small metal clip here. Simply pull it up.
  6. D-link DI-524 Teardown, Thats it!: step 6, image 1 of 1
    • You have successfully taken apart a D-link DI-524.
    • I was unable to remove anything more from the mother board as it is all soldered on.
Imad Knight
1,429 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 12
All Time: 2,597
