This teardown is not a repair guide. To repair your Datatronics Discovery 2400CM, use our service manual.
  1. Datatronics Discovery 2400CM Teardown, remove front cover: step 1, image 1 of 3 Datatronics Discovery 2400CM Teardown, remove front cover: step 1, image 2 of 3 Datatronics Discovery 2400CM Teardown, remove front cover: step 1, image 3 of 3
    • The front is attached to the body with 2 latches.
    • Using the spudger, open a latch on one side.
    • Open the latch on the other side next to detach the front.
  2. Datatronics Discovery 2400CM Teardown, remove back cover: step 2, image 1 of 2 Datatronics Discovery 2400CM Teardown, remove back cover: step 2, image 2 of 2
    • The back cover is attached to the body the same way as the front.
    • Open both latches to detach to back cover.
  3. Datatronics Discovery 2400CM Teardown, remove board from housing: step 3, image 1 of 3 Datatronics Discovery 2400CM Teardown, remove board from housing: step 3, image 2 of 3 Datatronics Discovery 2400CM Teardown, remove board from housing: step 3, image 3 of 3
    • The board is attached to the body with 2 screws. The screws are hidden under "warranty voidance" stickers.
    • Remove the stickers so you can unscrew the screws.
    • Slide the board from the body.
  4. Datatronics Discovery 2400CM Teardown, overview: step 4, image 1 of 3 Datatronics Discovery 2400CM Teardown, overview: step 4, image 2 of 3 Datatronics Discovery 2400CM Teardown, overview: step 4, image 3 of 3
    • Overview of the front and back of the board, as well as a detailed view of the label.
knipwim
8,685 Reputation
31 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 10
All Time: 939
