This teardown is not a repair guide. To repair your Dell Inspiron 7500, use our service manual.
  1. Dell Inspiron 7500 Battery Teardown, Dell Inspiron 7500 Battery Teardown: step 1, image 1 of 1
    • The battery....
  2. Dell Inspiron 7500 Battery Teardown: step 2, image 1 of 2 Dell Inspiron 7500 Battery Teardown: step 2, image 2 of 2
    • Underside of battery, as you can see the slide part comes off. the slide part is there to adjust for if the battery is on the left or right bay of the laptop.
  3. Dell Inspiron 7500 Battery Teardown: step 3, image 1 of 3 Dell Inspiron 7500 Battery Teardown: step 3, image 2 of 3 Dell Inspiron 7500 Battery Teardown: step 3, image 3 of 3
    • Top of battery pack with upper case removed. Case is NOT glued on, but is clipped on. You can see the case clips (and damaged top retention areas) from where I pulled it apart.
  4. Dell Inspiron 7500 Battery Teardown: step 4, image 1 of 2 Dell Inspiron 7500 Battery Teardown: step 4, image 2 of 2
    • Wiring. Three leads for balance charging., red and black are for the 14.8v connections. The pack is separated into 4 sets of 3 cells each run in series.
  5. Dell Inspiron 7500 Battery Teardown: step 5, image 1 of 2 Dell Inspiron 7500 Battery Teardown: step 5, image 2 of 2
    • Battery connector on PCB
Gary Sparkes
121 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 6
All Time: 902
