This teardown is in progress – Reload periodically to see the latest changes!
  1. Dell Quietkey SK-8000 Keyboard Teardown, Remove Back Plastic Body: step 1, image 1 of 2 Dell Quietkey SK-8000 Keyboard Teardown, Remove Back Plastic Body: step 1, image 2 of 2
    • Flip the keyboard over to expose 8 screws.
    • Use a Phillips screwdriver to unscrew and remove each screw.
  2. Dell Quietkey SK-8000 Keyboard Teardown: step 2, image 1 of 2 Dell Quietkey SK-8000 Keyboard Teardown: step 2, image 2 of 2
    • Lift the keyboard upward from the bottom.
    • Do not pull too hard when lifting the base. Be careful not to destroy the wires connecting to the base of the keyboard.
    • Use a Phillips screwdriver to remove the remaining ten screws on the aluminum plate.
  3. Dell Quietkey SK-8000 Keyboard Teardown, Completion: step 3, image 1 of 3 Dell Quietkey SK-8000 Keyboard Teardown, Completion: step 3, image 2 of 3 Dell Quietkey SK-8000 Keyboard Teardown, Completion: step 3, image 3 of 3
    • Carefully lift each part out. Each part should lift out very easily after the screws are removed.
  4. Dell Quietkey SK-8000 Keyboard Teardown, Siltek Chip Reveal: step 4, image 1 of 1
    • The keyboard controller is seen to be a Siltek R4462.
Ion
479 Reputation
3 Guides authored
Cal Poly, Team 10-5, Green Fall 2015 Member of Cal Poly, Team 10-5, Green Fall 2015
CPSU-GREEN-F15S10G5
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,003
