This teardown is not a repair guide. To repair your Dell latitude 3500, use our service manual.
  1. Dell latitude 3500 Teardown, Remove bottom cover: step 1, image 1 of 2 Dell latitude 3500 Teardown, Remove bottom cover: step 1, image 2 of 2
    • 10 screws total
    • The screws don't come the whole way out of the cover, but you will feel when they are loosened enough.
    • A spudger will make quick work of removing the cover, but you may have to open the laptop to find a spot for it to fit.
    • Sometimes the cover can snag when you go to pull it off: a snap may have caught again, or a screw may be hanging on by a thread.
  2. Dell latitude 3500 Teardown, Remove Battery: step 2, image 1 of 1
    • 4 screws total
    • Unplug it from the motherboard.
  3. Dell latitude 3500 Teardown, Remove RAM: step 3, image 1 of 1
    • Carefully push the metal latches on each side of the module outwards.
  4. Dell latitude 3500 Teardown, Remove M.2 SSD: step 4, image 1 of 3 Dell latitude 3500 Teardown, Remove M.2 SSD: step 4, image 2 of 3 Dell latitude 3500 Teardown, Remove M.2 SSD: step 4, image 3 of 3
    • One screw holds an aluminum plate in place over the SSD to disperse heat.
    • Another screw holds the actual SSD in place.
  5. Dell latitude 3500 Teardown, Remove USB/SD Card Reader: step 5, image 1 of 3 Dell latitude 3500 Teardown, Remove USB/SD Card Reader: step 5, image 2 of 3 Dell latitude 3500 Teardown, Remove USB/SD Card Reader: step 5, image 3 of 3
    • 2 screws
    • Carefully lift the black tab to free the ribbon cable from it's connection to the motherboard.
    • On the underside is where the CMOS battery is located.
  6. Dell latitude 3500 Teardown, Remove CPU Fan: step 6, image 1 of 1
    • Unplug the small fan header from it's slot on the motherboard
    • 2 screws total holding the fan in place.
  7. Dell latitude 3500 Teardown, Remove VGA Board: step 7, image 1 of 2 Dell latitude 3500 Teardown, Remove VGA Board: step 7, image 2 of 2
    • 2 screws total
    • the cable can be unplugged from the motherboard by carefully pulling up on the connector
  8. Dell latitude 3500 Teardown, Remove Wi-Fi Card: step 8, image 1 of 3 Dell latitude 3500 Teardown, Remove Wi-Fi Card: step 8, image 2 of 3 Dell latitude 3500 Teardown, Remove Wi-Fi Card: step 8, image 3 of 3
    • 1 screw total, holds a small bracket in place over the antennas.
    • Use a tool to carefully lift the antennas upwards from their connections.
  9. Dell latitude 3500 Teardown, Remove Touchpad: step 9, image 1 of 1
    • There's a small amount of tape that needs peeled back
    • 7 screws total
    • There's also a small lip on the top edge of the touchpad that will catch if you pull it out at an angle.
  10. Dell latitude 3500 Teardown, Remove CPU Heatsink: step 10, image 1 of 3 Dell latitude 3500 Teardown, Remove CPU Heatsink: step 10, image 2 of 3 Dell latitude 3500 Teardown, Remove CPU Heatsink: step 10, image 3 of 3
    • 7 screws total
    • The screws are numbered to spread the thermal paste the most evenly across each die.
  11. Dell latitude 3500 Teardown, Lift Hinges: step 11, image 1 of 2 Dell latitude 3500 Teardown, Lift Hinges: step 11, image 2 of 2
    • 2 screws on each side
    • These hinges hold the 2 halves together, so it will slide when you lift them up
  12. Dell latitude 3500 Teardown, Disconnect Remaining Connections: step 12, image 1 of 1
    • There should be three connectors still attached to the motherboard.
  13. Dell latitude 3500 Teardown, Remove Motherboard: step 13, image 1 of 3 Dell latitude 3500 Teardown, Remove Motherboard: step 13, image 2 of 3 Dell latitude 3500 Teardown, Remove Motherboard: step 13, image 3 of 3
    • 4 screws total
  14. Dell latitude 3500 Teardown, Remove Screen Cover: step 14, image 1 of 3 Dell latitude 3500 Teardown, Remove Screen Cover: step 14, image 2 of 3 Dell latitude 3500 Teardown, Remove Screen Cover: step 14, image 3 of 3
    • Spudge around the edges, even the hinge.
    • Thin(but strong) adhesive is placed around the border of the screen.
    • 4 screws holding screen in place.
Jake
1,327 Reputation
14 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 59
All Time: 1,785
