This teardown is not a repair guide. To repair your DirectPower DE157 Cordless drill-screwdriver, use our service manual.
  1. DirectPower DE157 Cordless drill-screwdriver Teardown, DirectPower DE157 Cordless drill-screwdriver Teardown: step 1, image 1 of 2 DirectPower DE157 Cordless drill-screwdriver Teardown, DirectPower DE157 Cordless drill-screwdriver Teardown: step 1, image 2 of 2
    • The driver kit.
    • This is a more-or-less no-name cordless screwdriver/drill kit, but its construction more or less matches most of these devices.
  2. DirectPower DE157 Cordless drill-screwdriver Teardown: step 2, image 1 of 3 DirectPower DE157 Cordless drill-screwdriver Teardown: step 2, image 2 of 3 DirectPower DE157 Cordless drill-screwdriver Teardown: step 2, image 3 of 3
    • The charger consist of a standard wallwart, output 14.4V 350mA, along with a little block (weighing nothing at all) to connect to one of the battery packs.
    • To open the charger block, unscrew three #1 Phillips screws.
  3. DirectPower DE157 Cordless drill-screwdriver Teardown: step 3, image 1 of 2 DirectPower DE157 Cordless drill-screwdriver Teardown: step 3, image 2 of 2
    • After lifting off the bottom, the PCB is exposed, and you can lift it out of the charger block along with the battery contacts. On the PCB we find:
    • A diode to protect against reverse current.
    • An LED and resistor that is on so long as the box gets power.
    • A giant 10 Ohm resistor to slightly current-limit the charge, and across which the green led and resistor are placed -- this will therefore light up as long as significant current passes to the battery.
  4. DirectPower DE157 Cordless drill-screwdriver Teardown: step 4, image 1 of 2 DirectPower DE157 Cordless drill-screwdriver Teardown: step 4, image 2 of 2
    • One of the two battery packs. To open, remove
    • Four #1 Phillips screws.
  5. DirectPower DE157 Cordless drill-screwdriver Teardown: step 5, image 1 of 3 DirectPower DE157 Cordless drill-screwdriver Teardown: step 5, image 2 of 3 DirectPower DE157 Cordless drill-screwdriver Teardown: step 5, image 3 of 3
    • After removing the screws, turn right side up again and lift off the plastic cover, exposing 12 NiCd cells in a string, and nothing else.
    • Note that there is room on the right side for three more cells, which would make a 18V battery pack.
    • Especially cheaper makers usually have versions for 7.2V/9.6V/12/14.4/18V all using the same plastic, just more or less cells and a different motor.
Jasper
136 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 2,458
