This teardown is not a repair guide. To repair your Fatshark FPV Headset 1000mah Battery, use our service manual.
  1. Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: step 1, image 1 of 3 Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: step 1, image 2 of 3 Fatshark FPV Headset 1000mah Battery Teardown, Disassemble the Battery Case: step 1, image 3 of 3
    • Cut the adhesive label down the seam of the battery case.
    • Do not cut down into the case as puncturing the battery will cause a fire.
    • Separate the two plastic case shells to expose the battery inside.
  2. Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: step 2, image 1 of 3 Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: step 2, image 2 of 3 Fatshark FPV Headset 1000mah Battery Teardown, Remove the Tape: step 2, image 3 of 3
    • Remove the tape holding the battery cells together.
    • Do not stress the tabs on the battery cells or short any of the metallic contacts on the internal circuit board.
  3. Fatshark FPV Headset 1000mah Battery Teardown, Desolder the First Cell: step 3, image 1 of 2 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the First Cell: step 3, image 2 of 2
    • Desolder the two battery tabs with black and white wires connected to them.
    • Do not short the battery cells or the metallic contacts on the internal PCB.
  4. Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: step 4, image 1 of 3 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: step 4, image 2 of 3 Fatshark FPV Headset 1000mah Battery Teardown, Desolder the Second Battery Cell: step 4, image 3 of 3
    • First, desolder the battery tabs from the PCB.
    • Second, desolder the main barrel connector wires and balance plug wires from the internal PCB.
  5. Fatshark FPV Headset 1000mah Battery Teardown, That's it!: step 5, image 1 of 3 Fatshark FPV Headset 1000mah Battery Teardown, That's it!: step 5, image 2 of 3 Fatshark FPV Headset 1000mah Battery Teardown, That's it!: step 5, image 3 of 3
    • Extra photos of components.
David Hoyt
4,023 Reputation
43 Guides authored
Cal Poly, Team 25-89, Amido Spring 2010 Member of Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Members
63 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 1,304
