Introduction
This is a teardown of the Fitbit Luxe to have a better understanding of the components within. The teardown was part of a design sprint for Memiro, research focused on self tracking and quantified self technology from IIT Institute of Design, Chicago.
Use a heat gun, hair dryer, or heating pad to heat the back cover
Wedge a spudger or other opening tool in the seem between the housing and back cover
Pry open the back cover evenly around the edge of the seem until back cover can be removed
Similar to the previous step, apply heat to the screen
Use a spudger, opening tool, or guitar pick to separate the screen from the housing
Use tweezers to lift the battery from the housing
Use a Torx screwdriver to remove the center screw
Using tweezers, gently remove the battery's connector from the PCB
Lift the battery out of the assembly
Locate the screen's connector on the PCB
Using tweezers, gently remove the connector from the PCB
Use tweezers to lift the haptic module connector from the PCB
Remove the haptic module
Use a Torx screwdriver to remove the two screws on the PCB
Use tweezers to remove the PCB from the housing
Yay you're done! Lay out all the components in true knolling fashion
Look for cracks, and board bents, especially near to the mounting holes (near the haptic feedback unit). My wifes luxe first stopped measuring, later started shutting down itself. When opened it I've found the battery very expanded, which have pressed the board outside and have cracked it, possibly tearing traces in the internal layers.
2 Comments
What chip or module would the firmware be on? I am trying to modify my Fitbit's operating system for more apps, and possibly Google Wear OS.
anybody know where i can buy parts for the fitbit luxe in EU ? looking for the Battery,
