This teardown is in progress – Reload periodically to see the latest changes!
  1. Fitbit Zip Teardown, Fitbit Zip Teardown: step 1, image 1 of 3 Fitbit Zip Teardown, Fitbit Zip Teardown: step 1, image 2 of 3 Fitbit Zip Teardown, Fitbit Zip Teardown: step 1, image 3 of 3
    • Use your iFixit Pro Tech Knife to slice and pry the different colored front and rear cases apart, as shown
  2. Fitbit Zip Teardown: step 2, image 1 of 2 Fitbit Zip Teardown: step 2, image 2 of 2
    • Remove the logic board/display assembly from the rear case
  3. Fitbit Zip Teardown: step 3, image 1 of 2 Fitbit Zip Teardown: step 3, image 2 of 2
    • Use your knife to slice off the bottom edge of the sticker found here on the rear of the board
  4. Fitbit Zip Teardown: step 4, image 1 of 3 Fitbit Zip Teardown: step 4, image 2 of 3 Fitbit Zip Teardown: step 4, image 3 of 3
    • Use a spudger to gently pry the display away from the logic board
    • Pry softly in each corner of the display, under the black frame
  5. Fitbit Zip Teardown: step 5, image 1 of 1
    • Seems to be it. The display doesn't appear to be separable from the logic board, sadly, making repairability completely out of the question.
Nathanael
959 Reputation
2 Guides authored
Beautiful Savior Lutheran Church Member of Beautiful Savior Lutheran Church
Business
1 Member
3 Guides authored
2 Comments
The display can be separated from the logic board, just pull it free from the logic board connector.
Yuri Silkin - Reply
My fitbit zip came apart at the seams. I decided to go ahead and clean the screen off since it was coming apart already and the screen looked dusty. Any ideas on how to put it back together? I goes back together and when I hold it everything functions, but I can't get it to stay together. Silicone? Glue? Any suggestions?
sweeney todd - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 9
All Time: 2,256
