This teardown is not a repair guide. To repair your Galaxy S23 Plus, use our service manual.
  1. Galaxy S23+ Teardown, Remove the SIM Tray: step 1, image 1 of 2 Galaxy S23+ Teardown, Remove the SIM Tray: step 1, image 2 of 2
    • Using a SIM card eject tool remove the SIM holder and the SIM if present.
  2. Galaxy S23+ Teardown, Remove the rear glass: step 2, image 1 of 2 Galaxy S23+ Teardown, Remove the rear glass: step 2, image 2 of 2
    • Using an opening pick and a suction handle, cut the underlying adhesive and remove the rear glass.
  3. Galaxy S23+ Teardown: step 3, image 1 of 1
    • Remove the 20 #00 Phillips screws.
  4. Galaxy S23+ Teardown, Remove wireless charging: step 4, image 1 of 1
    • Unplug the two connectors connecting the wireless charging to the motherboard and remove it.
  5. Galaxy S23+ Teardown, Remove the speaker: step 5, image 1 of 1
    • Disconnect the 5 connectors.
    • Remove the speaker.
  6. Galaxy S23+ Teardown, Unplug the front camera.: step 6, image 1 of 1
    • Unplug the connector of the front camera.
    • REMOVE THE FRONT CAMERA ONLY IF NEEDED BECAUSE IT'S GLUED TO THE SCREEN!
  7. Galaxy S23+ Teardown, Remove the Motherboard: step 7, image 1 of 3 Galaxy S23+ Teardown, Remove the Motherboard: step 7, image 2 of 3 Galaxy S23+ Teardown, Remove the Motherboard: step 7, image 3 of 3
    • Using an opening pick pull up the motherboard.
    • 12 MP Ultrawide camera.
    • 50 MP wide camera with OIS.
    • 10 MP telephoto lens camera with OIS.
    • Under this there's the RAM with the CPU.
    • A secondary microphone and the flash light.
  8. Galaxy S23+ Teardown, Remove the Charging Board: step 8, image 1 of 2 Galaxy S23+ Teardown, Remove the Charging Board: step 8, image 2 of 2
    • Use an opening pick to remove the speaker assembly.
    • Unplug the three connectors.
    • Unscrew the three Phillips #00 screws that secure the charging board and remove it.
  9. Galaxy S23+ Teardown, Remove the battery: step 9, image 1 of 2 Galaxy S23+ Teardown, Remove the battery: step 9, image 2 of 2
    • Using the tab provided, remove the battery.
Andrea Alfani
7,777 Reputation
5 Guides authored
Kid fixers Member of Kid fixers
Community
172 Members
229 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 172
All Time: 2,994
