Tools
This teardown is not a repair guide. To repair your Game Drive for Xbox, use our service manual.
  1. Game Drive for Xbox Teardown, Open the Cover: step 1, image 1 of 1
    • Using a Pry tool, remove the cover
    • This could break the plastic pins that keep the enclosure sealed. Nothing tape can't fix.
  2. Game Drive for Xbox Teardown, Remove the Cover: step 2, image 1 of 1
    • Take the cover off the drive
    • Lifting from the end without the USB port. Remove the drive from the case.
  3. Game Drive for Xbox Teardown, Remove the Shielding: step 3, image 1 of 2 Game Drive for Xbox Teardown, Remove the Shielding: step 3, image 2 of 2
    • Carefully peel away the shielding
  4. Game Drive for Xbox Teardown, Remove the USB Adapter: step 4, image 1 of 2 Game Drive for Xbox Teardown, Remove the USB Adapter: step 4, image 2 of 2
    • With careful pressure slowly pull the adapter off the drive.
    • Keep the adapter, it is Sata to USB 3.2 Gen 1, they have value
    • Don't pull from the end, you will likely break the adapter
Dan
4,484 Reputation
9 Guides authored
2 Comments
Good teardown Dan, A very enjoyable experence indeed
Cameron - Reply
ok, but after I pull the adapter off the drive, what next? How can I conect with laptop? I need another cable? What king of cable?
Anushka Dunyasha - Reply
Past 24 Hours: 6
Past 7 Days: 14
Past 30 Days: 60
All Time: 3,056
