This teardown is not a repair guide. To repair your glorious Model 02 Pro, use our service manual.
  1. Glorious Model O2 Pro Teardown, Flip Over: step 1, image 1 of 2 Glorious Model O2 Pro Teardown, Flip Over: step 1, image 2 of 2
    • Turn the mouse to the bottom
  2. Glorious Model O2 Pro Teardown, Remove feet: step 2, image 1 of 3 Glorious Model O2 Pro Teardown, Remove feet: step 2, image 2 of 3 Glorious Model O2 Pro Teardown, Remove feet: step 2, image 3 of 3
    • Remove top and bottom feet
    • Make sure to keep these and don't loose then
  3. Glorious Model O2 Pro Teardown, Remove Screws: step 3, image 1 of 3 Glorious Model O2 Pro Teardown, Remove Screws: step 3, image 2 of 3 Glorious Model O2 Pro Teardown, Remove Screws: step 3, image 3 of 3
    • Use a PH001 Screwdriver to remove both screws
  4. Glorious Model O2 Pro Teardown, Unclip Plastic Piece: step 4, image 1 of 3 Glorious Model O2 Pro Teardown, Unclip Plastic Piece: step 4, image 2 of 3 Glorious Model O2 Pro Teardown, Unclip Plastic Piece: step 4, image 3 of 3
    • (Ignore Bird Sticker)
    • Slide in an opening pick and gently wiggle across the plate
  5. Glorious Model O2 Pro Teardown, Same as step 4: step 5, image 1 of 1
    • After undoing the last clip the playe should come off to reveal…. (Drum roll) More Clips!
  6. Glorious Model O2 Pro Teardown, Remove Mouse Buttons: step 6, image 1 of 3 Glorious Model O2 Pro Teardown, Remove Mouse Buttons: step 6, image 2 of 3 Glorious Model O2 Pro Teardown, Remove Mouse Buttons: step 6, image 3 of 3
    • Insert a plastic spudger through the clips
  7. Glorious Model O2 Pro Teardown, Unscew: step 7, image 1 of 3 Glorious Model O2 Pro Teardown, Unscew: step 7, image 2 of 3 Glorious Model O2 Pro Teardown, Unscew: step 7, image 3 of 3
    • Make sure to get the 4th one that is horizontally straight from the other top screw
    • Keep these screws separate from the ones from the start these 4 are slightly smaller
  8. Glorious Model O2 Pro Teardown, Remove Inner shell: step 8, image 1 of 3 Glorious Model O2 Pro Teardown, Remove Inner shell: step 8, image 2 of 3 Glorious Model O2 Pro Teardown, Remove Inner shell: step 8, image 3 of 3
    • Do a combination of using the puck and prying with your hands use caution because the motherboard and battery cables can be damaged
  9. Glorious Model O2 Pro Teardown, Remove housing: step 9, image 1 of 2 Glorious Model O2 Pro Teardown, Remove housing: step 9, image 2 of 2
    • Lift it from the housing
  10. Glorious Model O2 Pro Teardown, Unplug battery: step 10, image 1 of 2 Glorious Model O2 Pro Teardown, Unplug battery: step 10, image 2 of 2
    • Unplug the JST connector from the lipo-cell battery
  11. Glorious Model O2 Pro Teardown, Remove mainboard: step 11, image 1 of 2 Glorious Model O2 Pro Teardown, Remove mainboard: step 11, image 2 of 2
    • Unscew the 3 smaller screws then remove mainboard from housing
    • Thanks for reading my first ifixit guide (R.I.P my prying puck)
0DanDan0
262 Reputation
1 Guide authored
3 Guide Comments
They removed the last photo with all the pieces 😭
0DanDan0 - Reply Share
can you send me the photo with all the pieces?
Fok Pop - Reply Share
Dont think i can...
0DanDan0 - Share
Past 24 Hours: 9
Past 7 Days: 57
Past 30 Days: 158
All Time: 1,900
