This teardown is not a repair guide. To repair your Google Pixel Buds 2, use our service manual.
  1. Google Pixel Buds 2 Teardown, Google Pixel Buds 2 Teardown: step 1, image 1 of 3 Google Pixel Buds 2 Teardown, Google Pixel Buds 2 Teardown: step 1, image 2 of 3 Google Pixel Buds 2 Teardown, Google Pixel Buds 2 Teardown: step 1, image 3 of 3
    • Features:
    • Sweat and Water Resistant
    • Bluetooth® 5.0
    • Spatial vent for in-ear pressure reduction and spatial awareness
    • Dual beamforming microphones / Voice detecting accelerometer
    • Up to 5 hours of listening time and up to 2.5 hours of talk time
    • Capacitive touch sensors / Dual IR proximity sensors
  2. Google Pixel Buds 2 Teardown: step 2, image 1 of 2 Google Pixel Buds 2 Teardown: step 2, image 2 of 2
    • What is in the box:
    • Buds Carrying / Charging Case
    • USB 'C' Cable
    • Ear bud rubber tips for different sizes of ears
    • User's Manual
  3. Google Pixel Buds 2 Teardown: step 3, image 1 of 3 Google Pixel Buds 2 Teardown: step 3, image 2 of 3 Google Pixel Buds 2 Teardown: step 3, image 3 of 3
    • Open the Google Pixel Buds Charging / Carrier case to locate the Buds
    • Once the Google Pixel Buds have been removed, and we can get a closer look at the Buds.
  4. Google Pixel Buds 2 Teardown: step 4, image 1 of 3 Google Pixel Buds 2 Teardown: step 4, image 2 of 3 Google Pixel Buds 2 Teardown: step 4, image 3 of 3
    • Back View of the Buds
    • Spatial Vent
    • Connectors for Charging the Battery when in the carrier / charging case
    • IR Detector for detecting when the buds are in the charging case or in the ear
    • IR Detector for detecting when the bud is in the ear
    • Grounded Metal Grid sound chamber cover
    • Closeup view of the Grounded Metal Grid
  5. Google Pixel Buds 2 Teardown: step 5, image 1 of 3 Google Pixel Buds 2 Teardown: step 5, image 2 of 3 Google Pixel Buds 2 Teardown: step 5, image 3 of 3
    • Microphone port. One on each side, and opposite one another.
    • Spatial vent / grounded mesh
    • IR Detector for in ear detection
  6. Google Pixel Buds 2 Teardown: step 6, image 1 of 3 Google Pixel Buds 2 Teardown: step 6, image 2 of 3 Google Pixel Buds 2 Teardown: step 6, image 3 of 3
    • Since the Google Pixel Buds are made of plastic and are glued together, the only way in was to cut into the Google Pixel Bud. This is a destructive teardown
    • Once in, we are able to get our first look at the Google Pixel Bud's electronics. The stack up the Google Pixel Bud is as follows:
    • Touch Sensor
    • Main Circuit board
    • Battery
    • Speaker
    • Microphones
    • Charging and in Ear IR Detectors (not shown)
  7. Google Pixel Buds 2 Teardown: step 7, image 1 of 3 Google Pixel Buds 2 Teardown: step 7, image 2 of 3 Google Pixel Buds 2 Teardown: step 7, image 3 of 3
    • View of the electronics when removed from the Google Pixel Bud Enclosure
    • Flex PCB based Touch Sensor
    • Main PCB. Contains MCU, Bluetooth Radio, Audio Processing, Power Management, and Sensors
    • Battery
    • MEMS Microphones
    • Speaker Coil, Speaker Magnet, and Speak Diaphragm.
    • Grounded metal grid sound channel cover
    • IR Detector for in ear detections
  8. Google Pixel Buds 2 Teardown: step 8, image 1 of 1
    • Closeup view of the Touch Sensor Flex PCB
  9. Google Pixel Buds 2 Teardown: step 9, image 1 of 2 Google Pixel Buds 2 Teardown: step 9, image 2 of 2
  10. Google Pixel Buds 2 Teardown: step 10, image 1 of 3 Google Pixel Buds 2 Teardown: step 10, image 2 of 3 Google Pixel Buds 2 Teardown: step 10, image 3 of 3
  11. Google Pixel Buds 2 Teardown: step 11, image 1 of 2 Google Pixel Buds 2 Teardown: step 11, image 2 of 2
    • Closeup view of the top side of the Main PCB
    • TI - BQ25150 - Battery Charge and Power Management
    • BES Technic - BES 2300 - Bluetooth Radio
    • Unknown Device - +7048/A5A59AB - May be the Accelerometer and Gyroscope used for voice detection. Please leave a comment if you know this device
    • Unknown Device - T 9 51 - Could be Flash Memory or RAM. Please leave a comment if you know this device
    • Unknown Device - SR 009 - Could be Flash Memory or RAM. Please leave a comment if you know this deviceNew line.
  12. Google Pixel Buds 2 Teardown: step 12, image 1 of 3 Google Pixel Buds 2 Teardown: step 12, image 2 of 3 Google Pixel Buds 2 Teardown: step 12, image 3 of 3
  13. Google Pixel Buds 2 Teardown: step 13, image 1 of 2 Google Pixel Buds 2 Teardown: step 13, image 2 of 2
    • Closeup view of the speaker Diaphragm
    • Speaker Coil with Speaker magnet removed
    • Speaker is ported to increase bass. Port area wraps around the outside of the speaker
  14. Google Pixel Buds 2 Teardown: step 14, image 1 of 1
    • MEMS Microphone
    • Could not cross reference the Microphone Part Number, but it appears to be a Goertek Part. Please leave a comment if you happen to know this component
  15. Google Pixel Buds 2 Teardown: step 15, image 1 of 1
    • Closeup view of the IR Detectors. Could not cross reference part numbers to a manufacture. Please leave a comment if you happen to know this component
    • IR Detectors are used to detect when the Bud is in the ear or in the charger
  16. Google Pixel Buds 2 Teardown: step 16, image 1 of 1
    • Closeup view of the Battery
    • Varta, CP1240 A3, Li-Ion 3.7V, 0.2Wh
  17. Google Pixel Buds 2 Teardown: step 17, image 1 of 1
    • Closeup view of the magnet that to holds the Bud in the charger. The magnet located is below the speaker in the sound chamber area
  18. Google Pixel Buds 2 Teardown: step 18, image 1 of 1
    • Teardown Exploded View of the Google Pixel Buds 2
    • Before and After
Robert Shuler
3,549 Reputation
11 Guides authored
26 Comments
Great teardown, I can see the effort and finesse that it took., Great job.
Steve Profit - Reply
Great job, better than iFixit!
pcbdata - Reply
Bru this is iFixit
Shmethan Shmichael -
Looks great…did you pop open the case as well?
trFixer - Reply
I would also like to see teardown of the case.
Nick Knudson -
Past 24 Hours: 15
Past 7 Days: 96
Past 30 Days: 377
All Time: 36,336
