HP 15-bs015dx Teardown
Video Overview
  1. HP 15-bs015dx Teardown, Remove the Battery - Part 1: step 1, image 1 of 3 HP 15-bs015dx Teardown, Remove the Battery - Part 1: step 1, image 2 of 3 HP 15-bs015dx Teardown, Remove the Battery - Part 1: step 1, image 3 of 3
    • Put the laptop facing down
    • Move the left battery safe lock to the right
  2. HP 15-bs015dx Teardown, Remove the Battery - Part 2: step 2, image 1 of 3 HP 15-bs015dx Teardown, Remove the Battery - Part 2: step 2, image 2 of 3 HP 15-bs015dx Teardown, Remove the Battery - Part 2: step 2, image 3 of 3
    • Slide the right battery safe lock to the left
    • This lock is harder than the previous, with this the battery should pop-up.
  3. HP 15-bs015dx Teardown, Remove the 6 visibles screws: step 3, image 1 of 3 HP 15-bs015dx Teardown, Remove the 6 visibles screws: step 3, image 2 of 3 HP 15-bs015dx Teardown, Remove the 6 visibles screws: step 3, image 3 of 3
    • Use a Philips 0 screwdriver
  4. HP 15-bs015dx Teardown, Remove the 4 hidden screws: step 4, image 1 of 3 HP 15-bs015dx Teardown, Remove the 4 hidden screws: step 4, image 2 of 3 HP 15-bs015dx Teardown, Remove the 4 hidden screws: step 4, image 3 of 3
    • Use a straw to take off just enough of the rubber feet of the 4 corners
    • Use a Phillips screwdriver 0
    • Replace each rubber foot in place after removing the screws
    • You will have a total of 10 screws
    the 2 bottom screws are stripped 😭 what do i doo
    4rtistime art - Reply
    You would need to use a drill set to reverse. Also, you need drill bits meant to remove screws. You can try "screw extractors" or other keywords to search for such online.
    Marcos Mora -
  5. HP 15-bs015dx Teardown, Remove the DVD unit: step 5, image 1 of 2 HP 15-bs015dx Teardown, Remove the DVD unit: step 5, image 2 of 2
    • It will go out easily with or without a straw
    • You can check the model number
  6. HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: step 6, image 1 of 3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: step 6, image 2 of 3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 1: step 6, image 3 of 3
    • Flip the laptop and open it
    • Use a plastic tool or a straw to separate the pieces of the chassis
  7. HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: step 7, image 1 of 3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: step 7, image 2 of 3 HP 15-bs015dx Teardown, Separate the pieces of the chassis part 2: step 7, image 3 of 3
    • Flip the laptop and separate the inferior cover of the chassis
    • Hard Drive 2.5" SATA
    • 2 RAM memory slots type DDR4 SO-DIMM
    • CPU Intel 7th generation
    • Active heat sink (fan)
    • Wireless card
    • Watch battery, 3V. CR2030
    Se puede sacar su procesador?
    johanluisos.com - Reply
    No. En este caso, el CPU es un core i5-7200u, el cual usa un zócalo tipo BGA, es decir, usa soldadura para pegarse a la placa base.
    Marcos Mora -
    Any info on how to swap out a non-backlit keyboard for a backlit keyboard for the 15-bs015DX? Thanks.
    David - Reply
    In this case, it looks like the whole plastic around the keyboard comes with it.
    I can't be sure, since I no longer have the laptop. Try to disassemble it and look if they sell a drop-in keyboard replacement
    Marcos Mora -
    What type of m.2 it support, and what type of m.2 socket it have. Thank you.
    Hocine Gasmi - Reply
    M.2 SATA-3. But I don't see a space to put on the m.2 screw. I recommend you open it up and double check.
    Marcos Mora -
    Me sirvió mucho muchas gracias
    Miguel ortega - Reply
    Sabrían como llegar al botón de power? Se me ha roto y necesito reemplazarlo, hay que quitar la placa base?
    Ferusti - Reply
42 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Marcos Mora
3,840 Reputation
11 Guides authored
21 Comments
Se me rompio las bisagras … como se reemplazan ?
Javier Horacio Monti - Reply
No tengo la laptop a mano para tomarle fotos, aunque en el paso 7 se puede ver algo. Depende de la rotura, lo típico que se rompe es la rosca para los tornillos, hay que crear un nueva rosca con material adicional, sin embargo, desconozco el procedimiento. En todo caso, puedes contactarme a mis RRSS que están en mi perfil de ifixit.
Marcos Mora -
Your step by step guide is apt. Thanks
Perebowei Titus Otoru Nigeria
Perebowei Titus Otoru - Reply
Buenas podrías hacer un tutorial desarmando y ensamblando la webcam
Javier - Reply
Saludos, ya entregué la laptop al cliente.
Marcos Mora -
Hola tengo una HP 15-bs038dx funciona un disco SSD M2 NVMe en ella o solo SATA? Muchas Gracias
Federico Barragán - Reply
Saludos, es difícil decirlo sin abrirla. La que tengo en fotos no tiene slot para m.2, por ejemplo.
Marcos Mora -
Hola y como se quita el teclado para limpiarlo, o es fijo ?
ayhdez - Reply
es fijo, pero puede limpiarlo con una brocha fina y pasarle una aspiradora
Luis Anniel -
Can I upgrade with SSD for this laptop?
Ram Krish - Reply
Yes! As long as it is a SATA 2.5" SSD
Marcos Mora -
Comprehensive explanation (especially for guitarists :-)))
Achim-Peter Gropius - Reply
Ou je peu trouvé la batterie
valeryjules33 - Reply
hi I have this laptop, and there was a power failure during a BIOS update, is there anything I can do to unbrick it?
Daniel Lopez - Reply
Try to search for HP guides, on its website about the topic. Also contact HP customer services.
Marcos Mora -
Hola Marcos muy buena tu guía.
Estoy trabado en el paso 6 porque  no se abrió totalmente.
Se levantan la parte del teclado pero en la parte superior queda como fijo pegado.
Tengo miedo forzar y romper lago,
Estoy en Argentina y la verdad no se que podría ser un pajuela. Probé con un elemento de plástico duro pero no puedo pasar de se paso y visualizar el interior d la laptop
Espero me puedas ayudar.
Gracias.
Gabriel
gabriel - Reply
Revisa que no te falten tornillos ocultos. Usa 2 o más pajuelas, para sostener varias partes a la vez, son baratas.
Marcos Mora -
como se llama la cinta que va del boton de encendido a la placa?
irving armenta - Reply
Normalmente es un "ribbon cable", o "flex cable". Eso como nombre genérico. En la fotos se pueden apreciar varios flex, para diferentes componentes.
Marcos Mora -
Mann wir sind nicht in England oder wo wir sind in Deutschland dann möchte ich alles auf Deutsch und nicht auf Englisch
Markus Schertel - Reply
Merci. Tuto Top
ForYou Only - Reply
Past 24 Hours: 29
Past 7 Days: 187
Past 30 Days: 851
All Time: 93,184
