This teardown is in progress – Reload periodically to see the latest changes!
  1. Hamilton Beach "Keep Warm" Toaster 22811 Teardown, Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 1, image 1 of 1
    • Unplug toaster from wall.
    • Do not take apart a toaster that is plugged in.
    • If toaster has been used, lay down paper towels or work outside to avoid making a mess.
  2. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 2, image 1 of 1
    • Remove crumb tray from bottom of toaster.
  3. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 3, image 1 of 1
    • Remove these 7 screws from bottom of toaster.
  4. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 4, image 1 of 1
    • Remove bread lifter/toast booster by prying it off. The plastic piece snaps over the metal part during assembly. Use a flat-blade screw driver from the side to widen the gap in the plastic clip while pulling the plastic handle out. Done right the handle can later be reassembled securely.
  5. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 5, image 1 of 1
    • Disconnect the two circuits by unplugging the wires shown. This can be done by pressing the lever on the crimps. Then the shell can be pulled off from the rest of the toaster.
  6. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 6, image 1 of 1
    • Remove these 2 screws.
  7. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 7, image 1 of 1
    • Remove this screw.
  8. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 8, image 1 of 2 Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 8, image 2 of 2
    • Remove these 4 screws.
  9. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 9, image 1 of 1
    • Pull apart toaster components. If power cable needs to be removed or adjusted, unscrew the screws circled.
  10. Hamilton Beach "Keep Warm" Toaster 22811 Teardown: step 10, image 1 of 1
    • If the circuit for the buttons and shade selector needs to be removed, unscrew these 4 screws.
Alexander Yazdani
846 Reputation
3 Guides authored
Cal Poly, Team S18-G1, Livingston Spring 2018 Member of Cal Poly, Team S18-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G1
4 Members
15 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 3,248
