This teardown is in progress – Reload periodically to see the latest changes!
  1. Holmes 16 Inch 4-in-1 Fan Teardown, Remove Frame: step 1, image 1 of 2 Holmes 16 Inch 4-in-1 Fan Teardown, Remove Frame: step 1, image 2 of 2
    • Remove holding pin on outer part of fan
    • Pull apart front frame from back frame
  2. Holmes 16 Inch 4-in-1 Fan Teardown, Detach Motor Housing  from Downrod: step 2, image 1 of 3 Holmes 16 Inch 4-in-1 Fan Teardown, Detach Motor Housing  from Downrod: step 2, image 2 of 3 Holmes 16 Inch 4-in-1 Fan Teardown, Detach Motor Housing  from Downrod: step 2, image 3 of 3
    • Remove screws connecting the motor housing to the downrod
    • Detach housing from downrod
    • Note: Oscillation Control will no longer function
  3. Holmes 16 Inch 4-in-1 Fan Teardown, Remove Motor Casing: step 3, image 1 of 3 Holmes 16 Inch 4-in-1 Fan Teardown, Remove Motor Casing: step 3, image 2 of 3 Holmes 16 Inch 4-in-1 Fan Teardown, Remove Motor Casing: step 3, image 3 of 3
    • Remove Oscillation Control pin
    • Remove back screw
    • Remove Motor Casing
  4. Holmes 16 Inch 4-in-1 Fan Teardown, Disconnect Stator from Rotor: step 4, image 1 of 2 Holmes 16 Inch 4-in-1 Fan Teardown, Disconnect Stator from Rotor: step 4, image 2 of 2
    • Remove the four screws connecting the stator to the rotor. The top two are displayed.
    • Detach the stator from the rotor.
    • Note: the fan will no longer operate.
Nicholas Steele
445 Reputation
1 Guide authored
Cal Poly, Team S9-G2, Banghart Fall 2017 Member of Cal Poly, Team S9-G2, Banghart Fall 2017
CPSU-BANGHART-F17S9G2
4 Members
14 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 291
