Video Overview
This teardown is not a repair guide. To repair your Honeywell Pull Station Fire Alarm, use our service manual.
  1. Honeywell Pull Station Fire Alarm Teardown, Testing: step 1, image 1 of 1
    • With it unplugged, set it on a flat surface like a stone.
    • This will make sure your pull station is level, making possible repair easier.
    • Pull down the pull station until there is a yellow tag saying "ACTIVATED." Then proceed to say "beep" 3 times.
    • Try not to pull it too hard and also make sure you do not directly spit into the station.
  2. Honeywell Pull Station Fire Alarm Teardown, Hammering Time!: step 2, image 1 of 2 Honeywell Pull Station Fire Alarm Teardown, Hammering Time!: step 2, image 2 of 2
    • Proceed to hit the pull station with a hammer also hitting the stone, making sure that the parts inside come out swiftly.
    • Do not try to drag it too much or else scratches will appear.
    • Pull down the station again multiple times to no avail.
    • A possible maneuver is taking a hard blow for the center, aiming your best shot, to literally "explode" the device and cause the parts to go everywhere.
  3. Honeywell Pull Station Fire Alarm Teardown, Center Blow: step 3, image 1 of 1
    • With your best shot, take a center blow at the pull station to cause the device to explode and parts to go everywhere.
    • Do it incorrectly and you risk several severe injuries.
  4. Honeywell Pull Station Fire Alarm Teardown, Final Thoughts: step 4, image 1 of 1
    • Repairability Score: 1 out of 10 (10 is easiest to repair
    • The teardown has several useful parts you can replace.
    • After the hammering and center blow, you have essentially destroyed the device making repair useless.
    • Go buy a new pull station
Gabi Salinas
2 Reputation
1 Guide authored
2 Comments
instructions unclear, the pull station is now hitting me with a hammer. 0/10 wouldn't recommend to anyone
techtalk11 - Reply
Amazing tear down. I actually wondered what these look like inside. The shards did hit my neighbors dog though.
Corbanizer - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 689
