This teardown is not a repair guide. To repair your Iomega ZIP 250 MB External USB, use our service manual.
  1. Iomega ZIP 250 MB External USB Teardown, Remove the Covers: step 1, image 1 of 1
    • Push pin into holes on sides to release the top blue casing.
    • Pull blue casing out of side slots located in each corner.
    • Remove the back end cover panel by pulling it outwards.
    • Remove front panel by inserting push pin into holes.
    • Remove the back panel.
    • Remove rubber feet nubs.
  2. Iomega ZIP 250 MB External USB Teardown, Access Internal Assembly: step 2, image 1 of 2 Iomega ZIP 250 MB External USB Teardown, Access Internal Assembly: step 2, image 2 of 2
    • Remove light silver screws (T6) from black piece on circuit board.
    • Slide the assembly out of bottom casing.
  3. Iomega ZIP 250 MB External USB Teardown, Separate Internal Parts: step 3, image 1 of 3 Iomega ZIP 250 MB External USB Teardown, Separate Internal Parts: step 3, image 2 of 3 Iomega ZIP 250 MB External USB Teardown, Separate Internal Parts: step 3, image 3 of 3
    • Remove four light silver screws (Phillips 00) on the bottom of the assembly.
    • Remove three black screws (Phillips 000) to remove disk drive from circuit board.
    • Remove the circuit board and admire.
  4. Iomega ZIP 250 MB External USB Teardown: step 4, image 1 of 1
    • Front Main PCB IC Identification:
    • You may need to enlarge it to view the text.
  5. Iomega ZIP 250 MB External USB Teardown, Removal of the Blue Part: step 5, image 1 of 3 Iomega ZIP 250 MB External USB Teardown, Removal of the Blue Part: step 5, image 2 of 3 Iomega ZIP 250 MB External USB Teardown, Removal of the Blue Part: step 5, image 3 of 3
    • Remove three silver screws (Phillips 000) from blue component.
    • Carefully peel off adhesive on wiring (flex pcb) to remove from blue component.
    • Unlatch the spring.
    • Lift and slide blue component out of disk drive casing.
    • Push blue tab on either side to release the blue casing from metal component.
    • Carefully peel off adhesive on wiring (flex pcb) to fully remove the blue component from metal.
    • Remove plastic arm and spring from drive body.
  6. Iomega ZIP 250 MB External USB Teardown, That Ejector Arm: step 6, image 1 of 2 Iomega ZIP 250 MB External USB Teardown, That Ejector Arm: step 6, image 2 of 2
    • Remove two springs from top corner (17mm) and middle section (20mm).
    • Remove two screws (Phillips 00) on back left corner of drive.
    • Remove eject button shaft by sliding out of slot in drive and lifting out off black arm.
    • Lift and twist the white latch on silver circle and slide the black arm sideways.
    • Slide out smaller black lever from drive body.
  7. Iomega ZIP 250 MB External USB Teardown, Disk Drive Body: step 7, image 1 of 1
    • Break spot welds by jamming a flathead screwdriver into cracks.
    • Remove gear system from back corner.
    • Remove black spring arm by pushing tab on bottom side of the case.
    • Break small white plastic plugs.
    • Remove circular reader from metal body casing.
    • Remove white plastic ring from reader.
    • Bend front door slightly to pop it out of casing.
    • You're all done! Pat yourself on the back.
    • Take a photo to remember this fantastical moment of your accomplishment!
Boo
145 Reputation
1 Guide authored
One Comment
I had a stuck cartridge and followed the instructions up to Step 3 where I was able to get it to eject! Put everything back together and the eject mechanism is working again!! Also added a bit of lubricant to the eject mechanism before I reassembled the unit. Sucess!! Thanks. :-)
GARY J WIMMER - Reply
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 15
All Time: 1,658
