Introduction
Go to step 1
I'm going to take apart a Kocaso SF70.
It's a tiny bit mistreated on the outside, but it's about under the hood, right?
Tools
Show more…
This teardown is not a repair guide. To repair your Kocaso Tablet Sofia 70, use our service manual.
  1. Kocaso Tablet Sofia 70 Teardown, Why this one looks weird..: step 1, image 1 of 3 Kocaso Tablet Sofia 70 Teardown, Why this one looks weird..: step 1, image 2 of 3 Kocaso Tablet Sofia 70 Teardown, Why this one looks weird..: step 1, image 3 of 3
    • The bent corner on the front is an attempt to lift the digitizer..
    • The bottom panel on the back went missing, and we tried to skin the top one with vinyl.
  2. Kocaso Tablet Sofia 70 Teardown, Removing the back cover.: step 2, image 1 of 2 Kocaso Tablet Sofia 70 Teardown, Removing the back cover.: step 2, image 2 of 2
    • Slip whatever pry tool you have in, then lift the device up from the cover.
    • The plastic buttons fall out, so be careful when you lift the cover.
  3. Kocaso Tablet Sofia 70 Teardown, The metal cover (Optional): step 3, image 1 of 2 Kocaso Tablet Sofia 70 Teardown, The metal cover (Optional): step 3, image 2 of 2
    • Use a smaller thing to get into one of the side holes.
    • (second image) Then you will be invited by Blu-Tack thermal stuff and the chips. I won't go into detail.
  4. Kocaso Tablet Sofia 70 Teardown, Ribbon cables.: step 4, image 1 of 1
    • To remove the ribbon cables, tuck something slim under the lock and push up. (Already done in the picture)
    • You don't need to take out the camera sensor's cable.
    • Be careful pulling!
  5. Kocaso Tablet Sofia 70 Teardown, Motherboard screws.: step 5, image 1 of 3 Kocaso Tablet Sofia 70 Teardown, Motherboard screws.: step 5, image 2 of 3 Kocaso Tablet Sofia 70 Teardown, Motherboard screws.: step 5, image 3 of 3
    • 3 Phillips. Top and bottom left corners, top right corner.
  6. Kocaso Tablet Sofia 70 Teardown, Removing the motherboard.: step 6, image 1 of 2 Kocaso Tablet Sofia 70 Teardown, Removing the motherboard.: step 6, image 2 of 2
    • There's tape holding down the motherboard, in case you didn't notice.
    • (second image) The battery has little adhesive, so lift it too and it's all off.
  7. Kocaso Tablet Sofia 70 Teardown, Antenna, Speaker, Mic + Vibrator: step 7, image 1 of 2 Kocaso Tablet Sofia 70 Teardown, Antenna, Speaker, Mic + Vibrator: step 7, image 2 of 2
    • Pull the speaker and microphone out.
    • The vibrator has an S on it. Slip something under it first, then push, then pull.
    • (second image) The antenna has two screws on the white part.
    • Not that I think you're dumb, but take care while pulling. These are soldered to the motherboard.
    • I chose not to remove the speaker bracket.
  8. Kocaso Tablet Sofia 70 Teardown, You're done!: step 8, image 1 of 1
    • Thanks for bringing yourself to read this.
some guy
223 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 409
