This teardown is not a repair guide. To repair your Korg Volca Mix, use our service manual.
  1. Korg Volca Mix Teardown, Remove the PCBs from the case: step 1, image 1 of 3 Korg Volca Mix Teardown, Remove the PCBs from the case: step 1, image 2 of 3 Korg Volca Mix Teardown, Remove the PCBs from the case: step 1, image 3 of 3
    • Remove eight screws.
    • Remove the bottom plastic case. You will see the PCB.
    • Remove four further screws and unlatch the two loudspeaker-jacks.
    • Remove the three Hi/Lo-Cut knobs and the three fadercaps. You can now remove the PCB from the case.
  2. Korg Volca Mix Teardown, The Top Side: step 2, image 1 of 1
    • Texas Instruments - TPS54231 2A, 28V-Input Step-Down DC/DC-Converter.
    • Texas Instruments - CD4013B D-Flipflop. I am not sure if this is correct. The Marking is CM013B/77K G4/A32G
    • National Semiconductor - LM386 Low Voltage Audio Power Amplifier
    • ST Microelectonics - STM32F030F4 Microcontroller.
    • JRC - NJM4556A Dual High-Current Operational Amplifier
    • ST Microelectronics - TL084CDT JFET Quad Operational Amplifier
  3. Korg Volca Mix Teardown, The Bottom Side: step 3, image 1 of 1
    • Texas Instruments - CD4013 D-Flipflop
    • ST Microelectronics - LT084CDT JFET Quad Operational Amplifier
Christian
1,560 Reputation
8 Guides authored
One Comment
thank's for this guide
Skander BEN M'RAD - Reply
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 27
All Time: 1,128
