This teardown is not a repair guide. To repair your Kyocera Oystr, use our service manual.
  1. Kyocera Oystr Teardown, Removing the battery: step 1, image 1 of 3 Kyocera Oystr Teardown, Removing the battery: step 1, image 2 of 3 Kyocera Oystr Teardown, Removing the battery: step 1, image 3 of 3
    • Make sure the phone is turned off before disassembly.
    • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
    • Remove the battery from the casing. This is simply a precaution.
    • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
  2. Kyocera Oystr Teardown, Removing screws from screen: step 2, image 1 of 3 Kyocera Oystr Teardown, Removing screws from screen: step 2, image 2 of 3 Kyocera Oystr Teardown, Removing screws from screen: step 2, image 3 of 3
    • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
    • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
  3. Kyocera Oystr Teardown, Exposing internal components: step 3, image 1 of 3 Kyocera Oystr Teardown, Exposing internal components: step 3, image 2 of 3 Kyocera Oystr Teardown, Exposing internal components: step 3, image 3 of 3
    • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
    • Remove the two screws from the metal cover.
  4. Kyocera Oystr Teardown, Removing metal cover: step 4, image 1 of 1
    • Remove the metal cover by lifting up and away from the device.
  5. Kyocera Oystr Teardown, Screen removal: step 5, image 1 of 3 Kyocera Oystr Teardown, Screen removal: step 5, image 2 of 3 Kyocera Oystr Teardown, Screen removal: step 5, image 3 of 3
    • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
    • Use your fingernail to detach the ribbon connecting the board to the screen.
    • Remove the damaged screen from the device.
  6. Kyocera Oystr Teardown, Completing the repair: step 6, image 1 of 1
    • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
David
24 Reputation
2 Guides authored
UW Stout, Team 5-7, Zhou Fall 2011 Member of UW Stout, Team 5-7, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G7
2 Members
4 Guides authored
2 Comments
where do I get a new screen?
LARS ANDERSEN - Reply
where do i get a new screen
thanks
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 14
All Time: 4,353
